It is currently Sun Jun 07, 2026 11:06 am
 Post subject: Secondary throttle
PostPosted: Wed Dec 10, 2003 9:10 pm
Does anybody know how to test the secondary throttle valve for operation on a stock craptachi carb, without the truck running. Well my truck still doesnt stay running. I have a brand new carb so any help would be appreciated, thanks
 Post subject: try this
PostPosted: Thu Dec 11, 2003 12:31 am
Make sure your ballist resistor is secure. One time I had that porblem and the wires were so gunked up I had to run a wire brush on the connection and the terminals. That fixed my stalling problem it did not cut out on me after that just a thought.
PostPosted: Thu Dec 11, 2003 6:00 am
again....with that avatar.....I just lost my train of thought.....HAHA!!!
03Cobra
PostPosted: Fri Jan 02, 2004 1:00 pm
Still drooling over the Avater.
But i have found that in some cases you want to use a conductive gook on them if there is that kind of problem. Like on the grounding straps, I simply put some gook on it when I am re-doing it then screw everything back in.
