It is currently Tue Jun 30, 2026 10:50 pm
 Post subject: DISTRIBUTOR
PostPosted: Tue Jul 31, 2012 8:45 am
Replaced my distributor cap yesterday and noticed the #1 plug wire was in the #2 spot, #3 was in the #1 spot, #4 was in the #3 spot and #2 was in the #4 spot. Before I had the engine rebuilt last November #1 use to be at the 2 o'clock position now it's at the 4 o'clock position. Any thought on why these plug wires would be changed. The truck is running fine. I am going to look into this in more detail this weekend.
76 LUV
 Post subject: Re: DISTRIBUTOR
PostPosted: Wed Aug 01, 2012 5:03 pm
May have the distributor turned to the wrong position and just moved the wires in the cap to match. Vacuum advance unit should point to the rear of vehicle or your left. Assuming 76-80 engines.
PostPosted: Wed Aug 01, 2012 9:28 pm
This is what it looks like. #1 plug wire is bottom right. It use to be top right.
76 LUV
PostPosted: Wed Aug 01, 2012 9:34 pm
Better pic.
76 LUV
PostPosted: Thu Aug 02, 2012 7:53 am
i ended up doing the same thing because i stuck mine in backwards so i just switched the wires around.
did it with the stock distributor and when i swapped to the electronic one i switched them back to the right way..
PostPosted: Thu Aug 02, 2012 11:51 am
Could the oil pump be 90 degrees off..
76 LUV
PostPosted: Fri Aug 03, 2012 9:15 am
Yes it can be installed wrong during the rebuild, however it hurts nothing so I would not worry about it at all.
There is a punch mark to line up on the oil pump drive that they probably paid no attention to. But as I said, hurts nothing.
PostPosted: Fri Aug 03, 2012 3:12 pm
agreed :lol:
the only problem that would come from it is that the wires would be backward :eugeek
PostPosted: Sun Aug 26, 2012 5:53 pm
i timed min backwards the book says time it on number 4 i timed mine on number 2 before i got a book so i switched my plug wires around becus number 1 and four are top dead center at the same time 2 and 3 are the same
if it aint a luv it aint shit
