It is currently Mon Apr 06, 2026 11:25 am
 Post subject: lugging
PostPosted: Sat Jul 14, 2012 11:48 pm
When I'm driving it lugs big time its 1978 sounds fagdgkthh then goes but takes couple min for it to fully ingage idk what's wrong its getting 111 degrees out side so don't know I'd the steel line next to the exhaust pipe are making gas evaporate
[color=#0000BF]luv truck 06.04.2011.[/color]
 Post subject: Re: lugging
PostPosted: Sun Jul 15, 2012 5:29 pm
so the problem your having is when you try to call down the thunder you get more of a firecracker? no power under load on a hill or acceleration or on flat land and cruising as well?
PostPosted: Mon Jul 16, 2012 11:51 am
Its vapor locking
PostPosted: Tue Jul 17, 2012 6:46 am
If this ever happens your fuel line under neithe are steal and the exhaust is turning the gas into a vapor after it goes threw your fuel pump or before to fix problem. I switch the whole fuel line to gas made piping made for gas to go away from the exhaust pipe also moved my fuel pump into the engine bay away from the hot parts next to my electric fan does not lag going up hill or going at high speeds
PostPosted: Tue Jul 17, 2012 7:32 pm
stock carb or weber? mine was having all kinds of problems until i finally ditched the stocker and got a weber 32/36.. dang thing stranded me a few times.
PostPosted: Wed Jul 18, 2012 6:18 pm
Ya man I was driving today and everthing I did was working but it started lugging way bad I think my jets or something up in it and its Weber carb
PostPosted: Wed Jul 18, 2012 6:44 pm
How do I get to the jets screws and how should I clean them
PostPosted: Wed Jul 18, 2012 7:38 pm
I was talking to one of my friends it could be my timing right
PostPosted: Thu Jul 19, 2012 1:32 pm
hows your fuel pressureand fuel pump mine burnt up a few pumps because i didnt wire a relay and when they are going out the truck will be jerking really hard going down te road as it gets and starves for fuel...
and then it will just stop going... lol
could be a clogged jet? or maybe it is a bit out of adjustment
