It is currently Sun Feb 08, 2026 1:27 pm
 Post subject: RPM guage
PostPosted: Sun May 20, 2012 10:27 pm
now i was just sitting here thinking how i would get a RPM gaude to work in my chevy luv if it never had one so idk what to do about that haha anythoughts??
 Post subject: Re: RPM guage
PostPosted: Mon May 21, 2012 6:19 am
You buy an aftermarket Tachometer at your local auto parts store or speed shop. And read the instructions on how to mount it to the steering column, and wire it up.
PostPosted: Mon May 21, 2012 7:11 am
Ok Haha do u think I would be worth the truble to try to get the old guages to work or go all new ones
PostPosted: Mon May 21, 2012 7:47 am
Wiring a tach is simple: signal goes to the distributor side of the coil (make sure the selector switch is set to the number of cylinders in your engine), light goes to dash light circuit, ground wire to the truck frame. Attach it to the steering column cover with a big hose clamp or some screws.
PostPosted: Mon May 21, 2012 9:54 am
Gas, or diesel?
