It is currently Thu Mar 19, 2026 12:59 pm
Post new topic Reply to topic  [ 81 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Liftin The Luv
PostPosted: Wed Nov 05, 2003 8:44 pm
Got an 80 Luv 4X4 and I want to gain enough clearance for 33's. any suggestions?
PostPosted: Thu Nov 06, 2003 7:06 am
Tork your torsion bars almost full , 8'' rear shackels , cut fenderwells...worked for me ! Check this thread http://forums.luvtruck.com/viewtopic.php?t=2717
PostPosted: Thu Nov 06, 2003 7:53 am
I was actually thinking of something a little more than that. If i crank up the torsion bars it will only give me 3 inches max. As for the shackles, that scares me a bit. The place I plan to wheel my truck at has lots of rocks and the shackles would just get hung up. Do you know of a pitman arm or idler arm that is lower than the stock ones?
PostPosted: Thu Nov 06, 2003 8:08 am
maybe you could look around a couple junkyards. check out some troopers. or something thats isuzu. impulse :?
PostPosted: Thu Nov 06, 2003 5:48 pm
if you really want to lift your luv, get a 80-85 toyota 4x4 frame and running gear, they will all bolt up.
Currently no more luv's... But in search of one!
PostPosted: Fri Nov 07, 2003 7:20 am
You mean to tell me that all the body mounts line up, or is some modification needed?
PostPosted: Mon Nov 10, 2003 12:10 pm
there shpuldnt be any modificaiton needed. some guy put a toyota body on a luv frame without changong anything.
PostPosted: Sat Nov 22, 2003 10:46 pm
my stock 79 luv 4x4 has the torsion bars cranked up,shackles "that dont hang down or catch any rocks",3"body lift,minor cutting of fenders,31x10.50 mudders.
PostPosted: Mon Nov 24, 2003 7:37 am
I just picked up a set of wheels with 31X11.5 Baja claws on them. :D Can't wait to see them on and kickin up rooster tails!
PostPosted: Mon Nov 24, 2003 2:41 pm
im happy with my thornbirds. cause with these, if you get sucked into a rut, you will end up kickin the ruts ass with the super side lugs. plus they are awsome on the sand.
PostPosted: Wed Nov 26, 2003 8:23 pm
i think you're the only person i've ever heard of having good luck with thornbirds :P looking at them, they have small voids in the tread, which results in crummy offroad traction
but back on topic, if you plan on lifting the truck, a toyota straight axle swap could be in order. you don't need whole frame, just weld on new spring and shackle hangers and bolt on those toy axles. diff drop is on the passenger side for the front, shouldn't be a problem there. plus you get all the added benefit of manufacturers that actually make parts for these axles. you can get several kinds of locker(electric, air, spool etc), chromoly shafts, super birfields, and all hi-pinion third members.
PostPosted: Fri Nov 28, 2003 7:07 pm
just get a toyota front solid axle and bolt that on. all u have to do is extend ur frame make shackle mounts and buy cross over steering at allprooffroad.com. make sure u get 4.10 in that front axle. i am looking for 4.56 for a toyota but no luck so far. but thats the way to go especially if ur into rock crawling. later matt
PostPosted: Sat Nov 29, 2003 11:55 am
id go with both yota axles, they have better aftermarket support and gears than a luv axle
stock ratios you could get with a solid front axle were: 3.90, 4.10, 4.30(rare), 4.38. HOWEVER, you can swap third members out of the rear axle of the non solid axle trucks(IFS) than ran from '86-95.5 into the front axle, since they use the same thirds. these have the option of 4.56 and 4.88. be careful with the 4.88 diffs though. you can't regear them, but you can put lockers in them, so if regearing isn't a problem, they're a good buy
here's some info on various toyota diffs
http://home.4x4wire.com/erik/diffs/
and here's a diff code chart that you can check if you pull something out of the junkyard(the code is under the hood on the passenger fenderwell)
http://www.off-road.com/toyota/tech/other/4_axles.html (scroll down a bit)
PostPosted: Mon Dec 01, 2003 7:36 am
What's the stock gearing in the 79 4X4 Luv? I thought it was 4.10 but I wanted to make sure.
PostPosted: Mon Dec 01, 2003 8:29 am
no stock 4x4 is 4.56 :P gears bro
PostPosted: Mon Dec 01, 2003 11:24 am
8O :D 8) I think I'll trade the 31's in on 35's now!!!!
PostPosted: Tue Dec 02, 2003 11:46 pm
hey now, it's 4.56s because of the lack of power the engine has :p
we're not talking about a fullsize rig here that can turn 33s easily on 4.10s, this is a luv with a 1.8l 4 banger. on average, with the little bit bigger(2.4l) toyota engine, you'd want to be running 4.88s for 33s
on a luv, i'd go with toy axles and 5.29 gears(don't ever use 5.71s, they're too weak on the 8")
you can regear yota axles to: 3.90, 4.10, 4.30, 4.56, 4.88, 5.29, and 5.71(not recommended)
PostPosted: Wed Dec 03, 2003 7:09 am
I'll try the 31's for now and see how that works out. I had an 86 Isuzu P'up with a 1.9 and it did pretty good with 31's and 4.10's. Maybe with a little luck I can get a break with home repairs and do a little work on the ol Luv.
PostPosted: Mon Dec 08, 2003 3:15 pm
a buddy of mine put 39.5's on the back of his 4x4 luv. it did fine........until he sheared the U joint off the drive line.
PostPosted: Wed Dec 10, 2003 11:13 am
Why did he only put the 39" tires on the back? If its a 4X4 That would really put strain on the t-case & driveshafts.
