It is currently Sat Feb 07, 2026 3:43 pm
 Post subject: No start new starter
PostPosted: Tue May 08, 2012 11:35 am
Guys My 75 Luv starter had a dead short.Was under warranty so I got a new one for free.New starter and still doesn't start.I know the old starter had a dead short because I could hear and see it arc.Could it be a fuse-able link? Ignition switch? Any input would be appreciated.
 Post subject: Re: No start new starter
PostPosted: Tue May 08, 2012 3:17 pm
Will it turn over if you cross the connections with a screwdriver?
PostPosted: Tue May 08, 2012 8:17 pm
I was short on time when I posted this.I did get the solenoid to engage.I put the starter in about twenty minutes before I had to go to work. The connections are tight. I am going to pick up some new cable ends for the positive side...looks like the cable is pretty corroded. I will use a test light and see if I have power at the two terminals that I think are fusible links on the positive side. Any other ideas?
PostPosted: Tue May 08, 2012 8:18 pm
I will go out and use jumper cables for a chassis ground and see if it will start.
PostPosted: Wed May 09, 2012 7:48 pm
Well after cleaning the connections for the chassis at the battery it started. Damnedest thing.Usually the grounds cause the problem.
PostPosted: Wed May 09, 2012 8:03 pm
this happend to me. the starter ran, the engine tried to turn over but it just would start. up buy the coil is a white block resistor, well thats what i call it, it comes of the coil, if this sounds like the same situation take of the resistor if its broke inside replace it it costs about 2 dollars to replace, i cary extras and i have had to cange this allong side the road, i was so proud, last time this happend it was a 100 dollar tow for a 2 dollar piece,
PostPosted: Wed May 09, 2012 10:32 pm
Thanks man...but as I said in my previous post..it is fixed.
Users browsing this forum: No registered users and 70 guests
