It is currently Thu Mar 26, 2026 6:51 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
PostPosted: Wed Nov 19, 2003 12:10 pm
Have a good chance on getting an 80 luv 4wd. I noticed that they sit fairly low. Wondering how difficult it is to get it up in the air and what parts/fab it would take. Not wanting to do anything crazy, maybe just a couple of inches for now.
PostPosted: Wed Nov 19, 2003 8:33 pm
i put a 3" body lift,shackles on the rear springs,and turned the torsion bars up for a total of about 6".then cut the corners of the fenders off and added 31x10.50 mudders.pretty simple for the way it looks after your done.[/list][/url]
PostPosted: Thu Nov 20, 2003 9:23 am
when i worked at a tire store i asked are alignment guy bout suspension lift on my truck he's a pretty smart guy alignment for 10 yrs he said your not supposed to do a suspension lift on a stock luv, but i am sure you can do a body lift on it though. so i guess thats sort of a beware i guess
PostPosted: Thu Nov 20, 2003 9:45 am
I put a 3'' bodylift on my 80. This is the company i used.....they sell 2'' or 3'' ...plastic or metal...resonable priced..and done in a weekend. Even though it says 81 luv, it is the same setup....good luck http://www.performanceaccessories.com/c ... eet001.htm if that dose'nt work, you can find it in users links, on the site.Image
PostPosted: Thu Nov 20, 2003 8:44 pm
if uy want to lift a luv do it the right way. get an 82 83 toyota solid axle from a pickup. then get the lift springs for it. u have to extend ur frame about 8 inches and have to buy allprooffroad.com cross over steering. its well worth it and it gives it a more original look. later matt
PostPosted: Thu Nov 27, 2003 11:30 am
I installed a 2" body lift within a day. Ordered from whitney. Approx. $100.00. Very easy w/ little to no mods. Way more included in kit than needed. Keep that in mind. There are 2" w/ some 3" parts included w/ this kit so can be confusing. This will allow me to run a 15x7 rally wheel w/ 235-75-15 tire. I will turn torsions to allow front to set up a little higher in the front just for looks. Cheap and easy
PostPosted: Thu Nov 27, 2003 3:13 pm
i bought my body lift from John Walls.he has a bunch of adds on ebay under chevy luv.think i give about 50 bucks but it was about 2 yrs ago.
PostPosted: Sat Nov 29, 2003 11:48 am
i'm with the solid axle idea too, if you want to lift your suspension. any front axle off a '79 to '85 toyota will work, and you can use any rear from a '79 to 95(86 to 95 are better, since they're 3" wider, and wont rub your tires on your frame at full articulation)
PostPosted: Sun Nov 30, 2003 10:31 pm
Where did you get the shackles? and if so how much were they?
PostPosted: Mon Dec 01, 2003 2:51 am
you can buy a set at pretty much any parts store. i paid 15 bucks for mine :D
PostPosted: Mon Dec 01, 2003 8:39 am
so with the toyota axle you dont need to mod the axle itself jus the frame and it will fit both rear and front
PostPosted: Mon Dec 01, 2003 1:11 pm
okay, one thing. an 80 luv, in NOT A SECOND GENERATION!!!!!!! the sec. gen is 81 and 82!!!!!!!!!!
Currently no more luv's... But in search of one!
PostPosted: Mon Dec 01, 2003 11:08 pm
Do they come in differnt sizes?
PostPosted: Mon Dec 01, 2003 11:29 pm
Quote:
so your sayin a toyota axle wont work on 80 luv only a 81-82 luv
PostPosted: Tue Dec 02, 2003 7:22 am
mine came in 3 inch. thats the most common kind your going to find. you'll could probably find 2 inch but i think you should go with 3 for the height.
it'll give you a pretty good height. remember the torsion bars will only go up 2 and a half inches without f*cking them.
i actually had to strecth my legs a little to get in mine.
if you want to go higher, jcwhitney.com has a body lift kit for 90 bucks.
PostPosted: Tue Dec 02, 2003 6:23 pm
I have the same lift on mine, though I has little diffiul cutting the firewall to get the steering to work correct. Also I have 215-75-15 and mine are really close to hittin the fenders? Did you do any mods to yours?
PostPosted: Tue Dec 02, 2003 11:10 pm
I know the 80 isnt 2nd gen. I posted a 2nd post admitting my ignorance. :oops:
PostPosted: Thu Dec 04, 2003 8:40 pm
bcg187 wrote:
Humor me, Got any onlinestores you can buy them? I tried JCwhitney and Kragens. Some of the stores around where I live, arent helpful with some parts when it comeds to a Luv.
PostPosted: Thu Dec 04, 2003 11:44 pm
Quote:
Some of the stores around where I live, arent helpful with some parts when it comes to a Luv.
join the club! try getting parts for em in australia. they havent even heard of a chevy luv
PostPosted: Fri Dec 05, 2003 7:09 am
it's not going to be a luv part.
it's universal. have you checked autozone, checkers, napa ?
it should be a part thats on the shelves. or just ask for leaf spring shackles.
if you don't have any luck ( you shouldn't ) but if for some reason you do i know the dodge darts have a set on them :)
