It is currently Sun Jun 28, 2026 11:24 am
Post new topic Reply to topic  [ 213 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: Norms 75 luv build
PostPosted: Thu Oct 27, 2011 10:20 pm
kellytye wrote:
thank you hotrod80 . thatas the nicest comment weve got on this littel luv . thanks again
i totally agree!
i wish luvs came factory that way.. power steering... horsepower to go with the stout chassis....
PostPosted: Thu Oct 27, 2011 11:22 pm
I find it funny how us un trained guys can figure out how to make their products better and more useful. And are the grease monkeys they build them for
PostPosted: Fri Oct 28, 2011 12:16 am
i would have to say that i agree with you guys . it takes a AMERICANS to do it right . the way we were going to go is with the 90 tropper 4x4 stearing and just change the tie rod ends , but the center link sits on top of the pitmen arm and it got into the oilpan . Im pretty sure that with the stock engine it well bolt right in with tie rod ends [ napa # 269-2918 ] , or for sure it well fit in the 4x4s . the frame rails on the 90 tropper at the front of the chassie are the same as all the luv frames [me4surment wise , so i would say that all the troppers are the same atleast up till 90 . you must use the idaler arm as well . OR just get the box and cut the hub off the piitmen arm and weld the old luv pitmen arm on . get it done by a pro , this is what keeps you going in right die-rection , have it tig welded and you wont have any problems. hope this helps
PostPosted: Sat Oct 29, 2011 5:54 pm
doors on and ready to put the guts in it
PostPosted: Sat Oct 29, 2011 10:13 pm
The truck looks great! I'm really diggin' the silver.
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Mon Nov 07, 2011 2:15 am
Kelly does awesome work! I have been over to his house and seen it first hand. I need to post some pics of my 76 convertible. Kelly is going to help me with a crossmember for putting in the 4x4 5 speed I'm doing.
PostPosted: Mon Nov 07, 2011 10:49 am
thank you for the comps. tony
PostPosted: Sun Dec 11, 2011 9:11 pm
got the steering column made and the stafts to the box made
PostPosted: Sun Dec 11, 2011 9:33 pm
the steering column is a piece of work . from the 90 tropper power steering box , the shaft from the box to the column is a 2000 nisson frontier , the lower shaft is a 90 tropper and the lower housing is 75 luv . the upper haft of the shaft and housing is 67 chevy . when i take it apart for paint ill get some better pics . the pump is a 90 tropper .
i allso got the headlight , markers ,turn signal and the wirers ill need for the fan all in and hide , go ahead and find them .
thats what youll see when were all done no wirers to be seen under the hood.
PostPosted: Wed Dec 14, 2011 3:09 pm
8O
that thing is looking great!
its the details like hiding the wiring and the customized steering setup that make these builds fun to follow. something a little different every time
PostPosted: Sun Dec 18, 2011 11:45 am
the steering column is welded
we made a washer to fit over the 75 tube and in side the 67 tube so it would keep a straight line through the tube
the coupler made it all possible
PostPosted: Sun Dec 18, 2011 6:56 pm
Very nice looking project you have going there!
You did a super job on that firewall and floor pan!
Waiting for updates!
PostPosted: Mon Dec 19, 2011 6:46 am
LSX LUV Owner
This thing is coming out awesome!
PostPosted: Tue Dec 20, 2011 10:09 am
got a great deal on sound deadner EBAY 1999 and free shipping for 5 square feet . half the price of dynamat .
PostPosted: Wed Dec 28, 2011 10:26 am
a littel more progress , pulleys and mounts for the alt . and power steering all done and powder coated
PostPosted: Thu Dec 29, 2011 8:03 pm
Is that the trooper pitman arm on the PS box? or was you able to install the stock LUV on the PS Box? Maybe I have the wrong PS box because my shaft on the PS Box is larger?........Please advise and explain thanks!
PostPosted: Thu Dec 29, 2011 10:35 pm
Hello sdeiter544 thanks for the intrest . the pittman arm hub that bolts on the tropper box stays , then cut the luv pittman arm . remember to take alot of measuerments and right them down . pay close attention to the up and down of the pittman arm so as not to hit the frame as you turn . the best way is to have a 2nd luv pttman arm so you can get the up and and side to side correct . the pittman arm is made of cast steel not cast iron so welding is easy . BUT I WOULD HAVE A PRO TIG WELD IT . I hope this helps if not ask again and ill try to come up with the right answer .
PostPosted: Fri Dec 30, 2011 1:52 am
whats the name of that color u use? its a nice silver!! keep up the great work!!
SALINASRACING.COM
PostPosted: Fri Dec 30, 2011 2:29 am
seabring silver
PostPosted: Sun Jan 01, 2012 8:04 pm
got a little done on the luv today . got alt. mounted and wired .
