It is currently Sun Jun 07, 2026 11:33 pm
 Post subject: Master cylinder problem?
PostPosted: Sat Sep 17, 2011 1:45 pm
The other day I was driving my truck and the pedal went to the floor with almost no braking power. I tried to bleed brakes, but got almost no fluid out of any of the lines. Could this be a bad master cylinder or brake booster?
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Sat Sep 17, 2011 2:51 pm
Most likely the master.
PostPosted: Sat Sep 17, 2011 4:36 pm
Yes, just the opposite if thebooster goes out, high, firm pedal. If you aren't losing fluid, it is the MC. Check NAPA.
PostPosted: Sat Sep 17, 2011 7:34 pm
Found a master cylinder at pick n pull. Pedal on that truck felt good. $12. Brakes now work great. Thanks for the help!!
PostPosted: Sun Sep 18, 2011 10:04 am
Make sure you bench bleed the replacement master before installing it, check the length(& adjust) of the piston rod, make sure when you bleed the brakes the engine is running to maintain vaccuum to the booster & prevent damage to the new master.
PostPosted: Sun Sep 18, 2011 10:09 am
8O Uh oh, I didn't do any of that. I just stuck her in and started bleeding. Crap! I really didn't know anything about having the engine running while bleeding. Hopefully I didn't damage it.
PostPosted: Sun Sep 18, 2011 11:25 am
I've never had the motor running when bleeding brakes. You can "bench bleed " on the truck. Have someone pump the peddle and just bleed it by cracking the lines you screwed into it. I would do that to make sure there is no air trapped up there.
PostPosted: Sun Sep 18, 2011 1:53 pm
Raidersadie, which pick n pull did you get that brake booster from. I have been to the one in Chico, and the selection of pre 1990 vehicles is getting pretty bad.
Mike
1980 Luv Mikado 2wd stock
1995 Ford F150 XLT 4X4
PostPosted: Sun Sep 18, 2011 2:31 pm
Oroville Self Serve Distmantlers on Feather River Blvd. They have an 82 4x4 and a 78 4x2
PostPosted: Tue Sep 27, 2011 4:03 pm
Ugh i keep for getting to get up there.... Body parts any good?
PostPosted: Tue Sep 27, 2011 5:58 pm
A couple fenders are ok. The beds are crap, bumpers crap, windshield good. Mostly engine compartment stuff and drive train. Interiors completely shot. There is an 86 isuzu trooper with a 5 speed and 2.3.
PostPosted: Wed Sep 28, 2011 8:01 am
That 86 Trooper has the 5sp that will fit your truck as well as the power steering and front upper control arms.
PostPosted: Thu Sep 29, 2011 2:12 pm
You are absolutely correct my friend. If I had the funds I would rape and pillage that trooper. One thing I don't understand is, why do I want the upper control arms? What is the benefit of this?
