It is currently Thu Mar 26, 2026 12:58 pm
 Post subject: v8 mpg ???
PostPosted: Tue Nov 18, 2003 8:39 pm
2 questions to anyone running "stock"v8s :lol: what kind of mileage are you getting and what is your drivetrain (moter size/tranny/axel ratios/tire size/ x-case if you got one) would like to know what to expect if i should decide to make this my daily driver thnx for the info :)
PostPosted: Wed Nov 19, 2003 10:22 am
Japanese Redneck
I ran a stock V8 once with the stock LUV 4.10 rear end gears,30" mudders TH350 trans. to answer your question... gas mileage = shitty
I would get a 700R4 overdrive trans and that will improve the mileage a LOT
PostPosted: Wed Nov 19, 2003 12:48 pm
l have a friend that runs a chevy V8 in LAND/ROVER and he's getting about 12 mpg l dont know if that is any help to you.
PostPosted: Wed Nov 19, 2003 5:01 pm
its a help. im just wanting to know what to expect from these setups. the 700r4 sounds like good advice. my friends father had a 502 caddy hooked up to the 700r4 in a full size truck and had someone install a second overdrive (maybe they put in a lock on the torque converter) and he said it would idle while pulling a ski boat at 55. 8O just what i was told
PostPosted: Thu Nov 20, 2003 2:15 am
That sounds more like my big rig 60mph and just revving at 1500rpm 8)
PostPosted: Thu Nov 20, 2003 10:08 am
Japanese Redneck
most likely that was a Gear Vendor under/overdrive unit. those are nice pieces but they are $$$. a 700R4 would do the job just fine. 4th gear is .72:1 i believe.
PostPosted: Thu Nov 20, 2003 1:35 pm
My dad has a built 302 w/ a c-6 tranny and 35" tires. when we first did the engine, it had and oversized race cam in it, mpg=5-8. when we finished the engine he got a smaller cam, mpg=14-18. theres a major mpg difference just by changing the cam.
Currently no more luv's... But in search of one!
