It is currently Mon Jun 08, 2026 3:56 am
 Post subject: Stereo for an '81 Luv
PostPosted: Tue Jul 19, 2011 11:39 am
Is there such a thing as a AM/FM CD unit that will bolt into my 1981? I realize that the dash plate opening will have to be enlarged, but other than that I don't want to do any cutting or fabrication. Any such bird?
Thanks!
Tom
Tom
PostPosted: Tue Jul 19, 2011 2:42 pm
Almost any single-DIN head unit will fit. It's possible some units are too long, but most of them are intentionally made as short as possible. I put my original bezel on a router table and cut out a DIN opening. That way, it covered the old knob holes that are in the dash. I posted photos of it at IsuzuPup.com, and maybe here somewhere. Here's the topic with a few photos:
http://www.isuzupup.com/viewtopic.php?f=34&t=9031
PostPosted: Wed Jul 20, 2011 11:45 am
Jack,
As always, you're a fountain of helpful knowledge. Thanks!!!!
Tom
Tom
PostPosted: Thu Jul 21, 2011 12:21 am
As usual Joe gave you some good information, I have done the same thing as he did, cut the dash carefully and almost any din radio will fit, there is plenty of room in the back of the radio face plate. I own a formerly diesel powered 81 LUV and have changed out the radio several times over the years. Good luck,
PostPosted: Thu Jul 21, 2011 8:25 am
One more bit of info that might be helpful. If you can get the entire dash bezel from an '86 or '87 P'up, it has a DIN opening--no knobs. There's still some exposed stuff that the radio faceplate might not cover, but you can make your own cover plate or trim your original one to fit the DIN radio.
PostPosted: Mon Jul 25, 2011 11:35 am
Knowing a DIN will work makes life so much easier!
Thanks!
Tom
Tom
Users browsing this forum: Bing [Bot] and 41 guests
