It is currently Sun Jun 07, 2026 4:56 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 22, 2011 2:12 pm
WOOO HOOOO!!!!! I believe that the problem is solved!!! yes, it was electrical! The terminals on the starter solenoid were very loose and the positive one especially so (the whole apparatus would shake back and forth). I put in a new starter (and alternator) and she started right up! I had her idling for a half hour or so while I adjusted the idle and timing, and took her around the block. She has a lot more pep with the new weber!!!! Thanks a lot for all of your advice everyone!!! I will post some pictures when I have a chance! :)!
PostPosted: Sat Jun 25, 2011 2:33 pm
hey all!
I made it back to Tucson! I had to adjust the idle on the weber a few times and she developed a small oil leak, but it is great to be back home after 6200 miles across the country with no A/C :) LUV POWER!!!!!
here are some pics of the truck on the trip and the stock carb and rebuild, I figure someone may find them useful (weber install pics to come)...
File comment: slept in the back of the truck in this vacant lot an hour outside Austin
File comment: parked in front of an old RT 66 motel in Santa Rosa NM
PostPosted: Sat Jun 25, 2011 2:35 pm
more stock carb pics:
PostPosted: Sat Jun 25, 2011 2:39 pm
vacuum lines to intake manifold:
File comment: the three vacuum lines to the intake manifold, can be a bit confusing...
File comment: close up of the three lines
File comment: the three vacuum line attachments on the intake manifold
PostPosted: Sat Jun 25, 2011 2:41 pm
more carb pics:
PostPosted: Sat Jun 25, 2011 2:42 pm
more:
PostPosted: Sat Jun 25, 2011 2:44 pm
float bowl and float:
File comment: float bowl with cover on
File comment: float bowl and float, don't lose that brass spacer on the pic when you take the float off!!!
PostPosted: Sat Jun 25, 2011 2:46 pm
takin' her apart:
File comment: accelerator pump
PostPosted: Sat Jun 25, 2011 2:49 pm
made a shim to replace missing one:
File comment: I noticed that a shim was missing from the behind one of the jets, the jet was totally loose... I created a new one (on right)
File comment: shims in place behind jets and secured with set screw
PostPosted: Sat Jun 25, 2011 2:51 pm
Glad to see you got her running. Something so simple can cause big headaches and expenses! Now you just need to clean dem dead birds out of da grill!!! :lol:
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat Jun 25, 2011 2:52 pm
installed the rebuilt carb!!!!
PostPosted: Sat Jun 25, 2011 2:57 pm
some close ups:
PostPosted: Sat Jun 25, 2011 2:58 pm
last but not least, a couple more close ups... thanks again all!!!!!
PostPosted: Sat Jun 25, 2011 3:00 pm
thanks Rick, them birds make her go faster!!!! :)
PostPosted: Mon Sep 26, 2011 9:21 pm
Hey, think this is my first post in a year or so, but here goes. Reviving this thread...
The voltage regulator controls the fuel pump. It makes sure that the fuel pump doesn't keep pumping gas all over you if you're unconscious and on fire. Usually helps after an accident or something like that. If the GEN light comes on, your alternator isn't putting out enough juice to keep the fuel pump relay closed. When the key is in the 'start' position, it overrides this function, allowing the engine to get gas and start right away. Figured this out when my voltage regulator quit on me a few years back.
So, if your truck won't run for more than 30 seconds, and your GEN light is on, concentrate on the charging system rather than buying a new carburetor, rebuilding your old one a few times, replacing your fuel filter a few times and otherwise going broke on replacing parts that aren't broken.
Kinda late for the situation in this thread, but maybe it'll help someone with the same problem in the future.
PostPosted: Tue Mar 13, 2012 1:05 pm
thanks for posting ret1614, I am sure that this advice will help someone in the future.
PostPosted: Tue Mar 13, 2012 4:58 pm
All the above correct. One more tip I have mentioned a few times: If the gen light comes on and the engine/fuel pump stops---just unplug the voltage regulator connector and drive on home. This then powers the fuel pump through the gen light circuit and gets you home, running on your battery of course.
Users browsing this forum: Bing [Bot] and 37 guests
