It is currently Mon Jun 08, 2026 1:33 am
 Post subject: "77 LUV torsion bar
PostPosted: Wed Jun 22, 2011 10:08 pm
Hi guys.... Haven't posted for a while but I need some advice. I tried to find this in the archives but, after about 15 minutes, I just couldn't find the archive section. I just added 15 inch rims and some moderately tall tires to my stock truck. Now, when I drive over rough roads I occaisionaly hear the left front tire rub somewhere on the body.___Haven't looked. I remember hearing that there is a 1/2 inch square drive bolt attached to the torsion bar that I thought about turning a couple of notches to 'raise' the body sllightly and stop the rubbing. That thing is probably pretty rusted by now though I live in AZ. Does anyone out there have any helpful hints to get this done without wrecking anything?? Thanks, Don
 Post subject: Re: "77 LUV torsion bar
PostPosted: Wed Jun 22, 2011 10:27 pm
spray it down with some wd 40, use a little bit of grease, and use a dremel or wire brush to clean the threads before you try turning it.
PostPosted: Wed Jun 22, 2011 10:35 pm
Thanks figuaris....Do you know how much up/down movement is gained by ...say, one full turn??
PostPosted: Wed Jun 22, 2011 11:25 pm
One full turn = 1/4".
PostPosted: Sun Jun 26, 2011 10:20 am
PB Blaster is a good solvent to spray on the bolts etc. Has a catalyst in it that helps break down the rust...works really good on piston rings that are stuck.
PostPosted: Sun Jun 26, 2011 1:38 pm
Hi Members....Yesterday I was able to get the torsion bar torqued up a bit more and the front end came up about 3/4 of an inch. The LUV looks more balanced now and I think the rubbing has stopped. Thanks for all your assistance.....Don
PostPosted: Sun Jun 26, 2011 9:47 pm
Now go get the front end aligned, your tires are likely going to start wearing more on the outside edge because you changed the camber.
PostPosted: Mon Jun 27, 2011 2:26 pm
Oldestizuzuist......Thanks, makes sense.......
