It is currently Mon May 25, 2026 6:45 am
PostPosted: Wed Apr 27, 2011 8:00 pm
I bought this distributor represented as a 1983-1987 Isuzu PUP 1.9 engine electronic distributor. Is this the right one to convert my Luv to electronic ignition? If so how do I hook up the wires?
Thanks!
PostPosted: Thu Apr 28, 2011 5:47 am
exactly what I have... your good to go
PostPosted: Thu Apr 28, 2011 6:40 am
Ok cool thank you, on the plug/connector did you cut it off to wire it up with the two individual wires or is there a mating connector that you used?
PostPosted: Thu Apr 28, 2011 10:45 am
When I bought mine off ebay it actually had the other end to it so I wired one hot wire and used the old ground wire
PostPosted: Thu Apr 28, 2011 1:12 pm
Ok got it, thanks for the help. I may be able to steal the other connector end off my Trooper parts truck if they are the same.
PostPosted: Fri Jun 03, 2011 12:30 am
hey im new to the Luv world. So i was wondering, any idea where i can get my hands on one of those distributers? Restoring a 1978 4x4 Luv. thanks :D :D
Danny Boy
PostPosted: Sun Jun 05, 2011 8:32 pm
I bought mine used off of ebay ($80.00 or so) there are also new replacements for around $200.00 on ebay, mine was from a 1984 Isuzu Pup with a 1.9 engine
PostPosted: Wed Jun 08, 2011 1:47 am
Thanks. ill have to look around on there then. I heard that Summit Racing made electronic ignition kits for the 1.8 but also heard they were around $500 :esurprised But if i get this done to my motor ill pretty much have done all i can do right? I already installed a header and Weber carb. But if you happen to see one of these lyin around please let me kno!!!!!!!!!!!!!! thanks
Danny Boy
PostPosted: Wed Jun 08, 2011 7:53 am
rockauto.com has remanufactured dizzys for about $80, fit '84-'87 pickups with the 1.9L engine.
PostPosted: Tue Jun 21, 2011 8:11 pm
thanks!!! :D
Danny Boy
PostPosted: Wed Jun 22, 2011 1:06 am
PITA Old Fart
There are two types...an earlier one with the ignition module mounted externally on the outside of the coil, and a later one that has the module mounted inside the distributor.
The internally mounted one is the best - but both will work.
PostPosted: Wed Jun 22, 2011 8:04 pm
Remember that for best results is to tune the motor to the later spec's.
PostPosted: Sat Sep 10, 2011 3:44 pm
i just ordered a 85 pup remaned distributor from rockauto with new cap and rotor
will be here the 15th. price including shipping with Bosch cap n rotor $112.70 great deal for a like new unit :)
where do i need to hook the wires? one is a ground i know but does the other go to + on coil or to + on battery? or?? i want to make sure i hook it up right when i get it
PostPosted: Fri Feb 15, 2013 11:01 pm
I bought a 1987 Isuzu PUP 1.9 engine electronic distributor to replace my points distributor on my 1980 Chevy Luv 1.8 engine. The distributor fits exactly the same, but no spark. I think that I'm not connecting it right. Can someone, who knows, please help me with this conversion?
Users browsing this forum: Bing [Bot] and 28 guests
