It is currently Wed Nov 05, 2025 12:23 pm
 Post subject: WEBER WIRING
PostPosted: Thu Apr 07, 2011 7:56 pm
Hooking up the weber was simple. However I have run into a problem. The wiring from my new 2.5psi fuel pump was connected to the old positive in replace of my old fuel pump, the wiring runs into the old hitachi carburetor? I have no power to the fuel pump with the key turned on thus I am not getting fuel to the carburetor. I am doing this right now and need help fast!!! how do i hook up the old wiring harness from the old carb to the weber????
anything helps thanks!
1974 Chevy LUV 4x4 Weberfied
 Post subject: Re: WEBER WIRING
PostPosted: Thu Apr 07, 2011 8:13 pm
This has nothing to do with a Weber. Who ever had your truck bypass the factory fuel pump wire and ran their own wire.
1. Do it right you need to trace a wiring diagram and fine the original wire and using a test light check for power when the ignition is on.
or
2. Use a relay to hook up you pump
or (rest of these are not a very good way to hook it up but works in a pinch)
3. The wires to the carb should be hot with key in running position and you can keep the wire hook up where it is. One wire should be your electric choke and the on the wire is for idel valve on the carb, forgot what it is called but the Weber does not have this set up.
4. Go to your fuse box and find and acc that is not being used and wire it in.
5. Hook the wire to the coil positive so you have power when the key is on for the fuel pump.
PostPosted: Fri Apr 08, 2011 9:08 am
If you have a LUV that came with the factory electric fuel pump you won't have power to the pump unless the engine is actually turning over, either running or cranking. This was a safety feature to keep the electric pump from gushing fuel after an accident. The Hitachi carb had a solenoid fuel shutoff also, as well as an electric choke wire. The power circuit to a factory electric pump goes from the ignition directly to the frame rail mount pump location.
PostPosted: Fri Apr 08, 2011 7:49 pm
thanks you guys. I had it all set up right in the first place just had to walk away from it for a min haha.
PostPosted: Fri Apr 08, 2011 10:03 pm
Heres a vid of my truck with the weber. running!
http://www.youtube.com/watch?v=yDNv5FKAkv0
PostPosted: Fri Apr 08, 2011 11:18 pm
i re wired mine to run to the "power" post on my ignition so i can let it run for a few seconds before i start the truck.
its really easy to run a wire to your ignition for it, just takes a good length of wire and a eyelet wire end, i ran mine along the same path the old one followed on the passenger side frame up to the engine bay and in through the fire wall. but you could just run it under the driver side and through the firewall. , you could put it to the running post.
PostPosted: Mon Apr 11, 2011 12:04 am
So from the choke to my ignition or from the fuel pump to my ignition?
PostPosted: Mon Apr 11, 2011 12:10 am
both of mine are wired to my ignition. partly for simplicity and partly because i didnt have the time to track down the problem before getting it running
PostPosted: Mon Apr 11, 2011 12:25 am
That may solve the problem Im having. when it starts cold, it quits right away until my 3rd or 4th time trying to start. It is quite annoying and then it will even back fire when i try to give it gas? any suggestions are appreciated thanks.
PostPosted: Mon Apr 11, 2011 12:29 am
I didnt mess with the location of the fuel pump wires just ran my choke to my 12v window washer wiring for the motor. And it worked fine with the key in on position. But its a bitch to get started is this because i should trace the wire and re put it back on my powerpost?
PostPosted: Mon Apr 11, 2011 4:59 pm
replaced the cap rotor points and condenser. Holy shit, fixed all the issues im stoked. Runs like a bullet from a fresh gun now. The old cap and rotor were so fucked haha. I cant believe it was something so easy this whole time I think i even purchased the weber when my hitachi was working fine but o'well worth every penny if you ask me. Thanks for the help guys.
PostPosted: Mon Apr 11, 2011 9:19 pm
Hatachi new does not work fine, I've own plenty of LUV trucks. The Weber works awesome. I have gotten a few LUV trucks for free due to the carb or dizzy not working properly.
PostPosted: Tue Apr 12, 2011 8:48 pm
pump the gas once before you turn the key and then dont touch it again. will set the idle switch or whatever u wanna call it on the carb so it will fast idle till it warms up as you dont touch the gas again and drop it off. if it dies the first time do it over mine usually starts and idles the second time in the cold. mine is always sluggish when cold and doesnt like to GO until it has warmed up but it can be driven lol
PostPosted: Tue Apr 12, 2011 11:11 pm
Just figured that out for myself this morning. She is running so great i cant believe it honestly. Thanks again for all your help and this site. Is it horrible to start driving before she is warmed all the way up? She did fine when i was late to work this morning haha.
PostPosted: Wed Apr 13, 2011 1:10 am
not ALL the way warmed up but i usually give it about a minute to warm up and get the whole cycle going steady
the weber makes a huge difference in response doesnt it :lol:
PostPosted: Wed Apr 13, 2011 2:22 pm
Exactly, I only wait until the operating temp has moved up into the lined area then she runs great and warms up fast.
