It is currently Mon Apr 06, 2026 3:43 am
PostPosted: Sat Apr 09, 2011 3:07 pm
Well I moved to Washington but had a family emergency back here in Olahoma
OK there is a rattle coming from the back of my engine. Its not a knock its just a rattle. The engine was just rebuilt and all bolts were torqued to spec then pulled the engine and made sure the bolts were still torqued right. Yet however it still has the rattle. The only thing I can think of is somehow the clutch is rattling which is also brand new or possibly the flywheel is cracked. Any ideas would be helpful because this is the only thing keeping me from driving it now :(
PostPosted: Sat Apr 09, 2011 3:36 pm
maybe your throw out bearing
PostPosted: Sat Apr 09, 2011 3:40 pm
It's also new :/
PostPosted: Sat Apr 09, 2011 4:28 pm
pilot bearing possibly
PostPosted: Sat Apr 09, 2011 4:47 pm
Well its also new. The rattling stops once I let out on the clutch then starts rattling again once the RPMs level out.
PostPosted: Sat Apr 09, 2011 4:58 pm
I have the same noise coming from my truck when the rpm's are leveled out right around 24-2700 rpm. Has been doing it for about 500 miles now and I still havent got it figured out so best of luck to you
PostPosted: Sun Apr 10, 2011 3:12 pm
Ok let me know if u figure it out and I'll let you know if I figure it out.
PostPosted: Sun Apr 10, 2011 8:14 pm
sounds good....
PostPosted: Mon Apr 11, 2011 7:49 am
i have seen a lot of starters go out and give a rattle
I will no longer do that thing with my tongue
PostPosted: Tue Apr 12, 2011 3:27 pm
Is your noise getting any better?
PostPosted: Wed Apr 13, 2011 8:53 am
I haven't had the time to mess with it. I probably won't get around to it til this weekend.
