It is currently Mon May 25, 2026 6:45 am
 Post subject: Replacement speedometer
PostPosted: Tue Mar 22, 2011 6:40 pm
Just a quick question, does anyone on here know of a suitable replacement for a 1982 Luv diesel? Mine shows how fast I am going, but it does not run the mileage that I have traveled.
Thanks, Dennis
dcarterf@gmail.com
PostPosted: Tue Mar 22, 2011 6:55 pm
Thanks, Dennis
dcarterf@gmail.com
I sent you a PM about the speedometer--but then I re-read the post. That's a common problem, and there's no need to replace the speedometer for it. Just need to clean the old grease out of the odometer gears. There's a "How-to" article titled Stuck Odometer Repair that's for P'ups, but the '82 LUV is identical. It might even be pretty close for 1st-gen LUVs.
PostPosted: Sun Apr 17, 2011 10:36 pm
Hi Joe,
Is the speedo on a 81-81 Luv the same as the 82- Pups? Just curious?
BTW, I just posted some info on classified about making a removeable trans crossmember for 81-82s along with some modified sbc oil pans that I think might also fit Pups. Do you know if the engine compartment is the same on 81-81 Luv and Pups?
Thanks for the information,
dusty
PostPosted: Mon Apr 18, 2011 8:40 am
scjconv wrote:
Hi Joe,
dusty
The '81 and '82 LUVs and P'ups are identical other than trim and badges.
Users browsing this forum: Google [Bot] and 20 guests
