It is currently Sun Jun 07, 2026 7:30 pm
 Post subject: Windshield washer Help
PostPosted: Tue Feb 22, 2011 10:37 pm
i have a broke peace in my washer system. it the piece that goes from the flex tub to the pert of the nossel that sticks into the engine compartment. where do i get this part?
"but still try, for who knows what is possible..."- Micheal Faraday.
'81 white Luv Mikado 4x4 with nearly all the options. Granddad bought it new.
PostPosted: Tue Feb 22, 2011 10:56 pm
I did the exact same thing. You might be able to find a part off of a different vehicle. I found one in a box of random stuff at a pick and pull, not sure what it came out of, but it works.
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Wed Feb 23, 2011 10:17 pm
thanks! that'll have to waght till summer. anyone parting one out i wanna know see if i can get the whole system nossels and all
PostPosted: Wed Feb 23, 2011 10:29 pm
I dont know if this would work or not. Try a piece of tubing that will fit tight into the hose and put a piece of small wire in the other end and smash the tubing around the wire with a vise then pull the wire out and bend to fit. cost a quarter.
1980 4x4
PostPosted: Wed Feb 23, 2011 10:47 pm
i'll keep it in mind, if i was in kinya that would be what i do. being i'm in the USA i'll try to find a replacement part. if i can't do that i shore will do that for a quarter!
PostPosted: Wed Feb 23, 2011 10:51 pm
Thats what is wrong with America.
1980 4x4
PostPosted: Wed Feb 23, 2011 11:07 pm
yes and no. if you can afford luxerys then use 'em. i'v jimmy rigged so much stuff i'm tired of it, i want to put things truly right for a change. if i could "glue" it back together i would. i want to turn this into a show truck, so i want it close to original. if it was a work truck i could care less.
PostPosted: Thu Feb 24, 2011 8:22 pm
if you go to an auto parts store, in their HELP! section, you should find a few replacement universal assortment nozzles. if you want originality, stick with the pinched tube. otherwise you can update the spray nozzle and the spread of the washer fluid. i used some from my wife's metro in the hood. worked great, and it looked good.
PostPosted: Thu Feb 24, 2011 8:41 pm
k i'll try to get the to autoparts this month. let me refrase that, restored, not original. sorry for confusion.
PostPosted: Thu Feb 24, 2011 9:32 pm
There's an '86 P'up at the Pull-A-Part in Charlotte. It was placed on the lot on January 5, so it may not be there much longer. Best to check their inventory on their website before you go...just in case it's been crushed.
This fitting may not be worth the trip, but you should be able to pick up some good spares like taillights, signals, wiper switch, and who knows what else.
If it has a nice long bed, let me know! ;)
PostPosted: Mon Feb 28, 2011 11:24 pm
not on there inventory :(
