It is currently Mon Jun 08, 2026 1:50 am
PostPosted: Tue Feb 01, 2011 7:35 pm
I am having a rough time getting my 80 Luv to pass smog, and I was wondering if anyone in California has used this CARB excemption order to get their truck to pass smog? Here is the link to the order http://arb.ca.gov/msprog/aftermkt/devic ... 133-13.pdf
It basically says that Luv trucks from 72-79 can use a Weber Redline carburetor kit and throw away the stock carburetor, along with throttle positioner, the deceleration control valve. Also, associated vacuum hoses may be tossed according to the manufacturers instructions. As long as you install the carburetor according to Weber, and it passes a smog test, your good to go. My problem is my truck is a 80. I was wondering if anyone here in the god forsaken state has any experience with this before I pull the trigger and purchase a Weber?
1980 Luv Mikado 2wd stock
1995 Ford F150 XLT 4X4
PostPosted: Tue Feb 01, 2011 7:59 pm
That's a new one on me, but I like the sound of it. Just go and talk to a smog referee before you do anything. They will tell you what you can and can't do. And they are also the ones that issue the sticker, so it pays to pick their brain first.
PostPosted: Tue Feb 01, 2011 10:26 pm
I'm not sure if they will let you. If I remember right wasn't it 1980 and after that ALL vehicles HAD to have smog stuff? Don't quote me on that I don't remember exactly.
When in doubt floor it. If you can't floor it then you've doubted yourself.
PostPosted: Wed Feb 02, 2011 6:16 pm
Put the weber on and the stock airfilter, most smog shops wont notice
PostPosted: Thu Feb 03, 2011 10:44 pm
Will a weber pass the smog test?
PostPosted: Fri Feb 04, 2011 1:13 pm
I had one that did. I just sold the truck last year.
PostPosted: Mon Feb 07, 2011 7:25 pm
If anyone of you talk to a smog referee, let us know what they say about the 1980. I for one, would like to put a Weber on my 80 4x4.
Thanks! 8)
PostPosted: Tue Feb 08, 2011 12:08 am
I found a site called smogtips.com. There's a question section you can submit to a referee and get an answer within 24 hours. I asked if the Executive order D-133-13 can apply to the 1980 model. If that doesn't work, I'm going to ask my local smog shop. I will post what I find out.
PostPosted: Tue Feb 08, 2011 1:48 pm
I got an email reponse back from smogtips.com
"Unfortunately not. Your replacement carburetor must have an EO number
specifically for your 1980 Chevy truck"
I think I will ask my local smog shop about talking to a referee. Who knows, it might be like going to the DMV, where you go to the same building with 2 employees but 2 different answers.
PostPosted: Tue Feb 08, 2011 2:29 pm
After reading all of these posts, I'm glad I live in N.C.! No emmisions testing for vehicles 1995 or older!
1990 Chevy Suburban
PostPosted: Tue Feb 08, 2011 6:05 pm
It seems like it is easier to do a V8 swap.
viewtopic.php?f=6&t=22153
http://brotherhoodofstreetracers.smffor ... /index.php
http://brotherhoodofstreetracers.smffor ... 539.0.html
Quote:
How to do a California legal EFI engine swap:
by Brad Bergholdt
Automotive Tech Instructor at Evergreen State College in San Jose, CA
The state of California allows you to swap a wide assortment of engines into your car or truck, as long as the engine is the same year or newer than the chassis, and all of it's emission controls are intact. Problem areas could be a heavy duty vs. light duty truck engine swap, or a CA vs. federal engine swap. Also, I don't believe it's permissible to downgrade from fuel injection to a carburetor, or from a feedback fuel system back to a mechanical one. To play it safe, you'll want to pick up and read the state's engine swap pamphlet (available from the Bureau of Auto Repair), and ask a question or two of the smog referee before getting too far along. Most CA Consumer Assistance Centers (smog referees) are located in a community college, and you should be able to stop by, without an appointment, for some quick advice.
PostPosted: Tue Feb 08, 2011 7:10 pm
I think there are a number of post in the drivetrain upgrade section on engine swaps, including CA owners.
Thanks for the info though. However I think most of the people on this post want to keep their stock motor and upgrade their carburetor. I left a message with my local smog tech about contacting a smog referee.
Well hopefully be able to talk to one tomorrow.
PostPosted: Wed Feb 09, 2011 9:41 am
Don't get me wrong, I'm interested also cause I have more than one truck and several have 4 cyl. They make it so difficult that it just seems ironic that it seems easier to do a swap than keeping it stock. I like it both ways, V8 and with a Weber swap. V8 is exciting to drive and the Weber swap is a blast to drive and good MPG to boot even if you drive it fast.
PostPosted: Wed Feb 09, 2011 11:48 pm
I took it back and explained the situation to the guy and he passed it.
What about a V6 swap?
PostPosted: Thu Feb 10, 2011 9:34 am
Did he pass it with a Weber on an 80 LUV?
PostPosted: Fri Feb 11, 2011 8:06 pm
I talked to Redline. I told them I had an 80 Luv, and that the Smog Ref had said I would need a Carb with EO on it.
The guy was not very helpful. All he said is "we don't have any Carbs for the 1980 Chevy". Though they have 5 models with DCOE on their carbs on the website. Go figure.
I don't get why the 79 is included and not the 80. I don't know of any diffrences, at least mechanically.
I think California should get rid of the C.A.R.B. and save the state some money. :lol: :D
Well I may end up being in the market for a 75 Luv, and putting it on my chassis. No smog for 75 and older (use to be a roll over year, but 75 is the last year).
PostPosted: Fri Feb 11, 2011 11:30 pm
Man-oh-man you cali guys have it rough. I grew up in South Carolina and they have vehicleGood luck inspections but not to the severity you guys are mentioning. I've been in Montana since 1986 and we have no inspection of any kind. (sometimes I think we should if you could see some of what I see on the road) Good luck with all this.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Thu Mar 03, 2011 8:42 pm
Well, as much as I hated to do it, I went with a rebuilt carburater. I didnt want to have to explain anything to my mechanic. He would have smogged it with the weber, but I didnt want to ask him to break the law. My new issue is the catalytic converter. Before the carb swap, my truck was a "gross polluter". Now, it passes the idle test, and is over at 2500 rpm. My truck smogged .37 over the 2.00 max. He thinks a new cat will work. Now, if anyone in California has ever shopped online for a replacement cat, you will see some pretty good deals on 49 state cats. $40 universal, and $90 for fitted ones. For California, they are $140 for universal, and $230 for a fitted one. Muffler shops are about the same. Thinking about going to Reno and buy a universal, but I need to know what that sensor in the cat is, and if it is actually connected to something important. Anyone have any ideas?
Users browsing this forum: Bing [Bot] and 35 guests
