It is currently Tue Mar 17, 2026 1:20 pm
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Thu Jan 06, 2011 6:35 pm
You HAVE to video the start up, cause you are too far away for me to come by and watch. :popcorn:
PostPosted: Fri Jan 07, 2011 4:54 pm
LSX LUV Owner
i bought a map sensors today. keeps getting shorter and shorter.
got overflow setup today. map sensor put in. oil pressure and water temp sensors in and hooked up to wiring. fuel line made up. so fucking close. bought a gas pedal from a voyager?, gas door from a jeep truck, and a comp tray from a 99 blazer for 27$.
radiator fluid
engine oil
trans fluid
rear end fluid
ls7 maf with housing
belt
PostPosted: Sat Jan 08, 2011 12:37 am
damn 8O
how much do you have into this swap so far!
PostPosted: Sat Jan 08, 2011 8:12 am
LSX LUV Owner
motor swap? i dunno.. its been a little more then a motor swap :lol: . i haven't kept track of price at all.. its better that way.
PostPosted: Sat Jan 08, 2011 12:12 pm
LSX LUV Owner
shitty iphone vid
PostPosted: Sat Jan 08, 2011 12:58 pm
ITS ALIVE!!!!!
PostPosted: Sat Jan 08, 2011 8:45 pm
:ebiggrin :ebiggrin :ebiggrin :ebiggrin
Larp like
Next video i wanna see is you cruising down the street giggling like a schoolgirl :P
PostPosted: Sat Jan 08, 2011 8:48 pm
A one of a kind 2011 luv... Awesome
PostPosted: Sat Jan 08, 2011 9:52 pm
LSX LUV Owner
next vid will be better quality. in a few weeks i should have one of me driving it down my street.
PostPosted: Sun Jan 09, 2011 6:52 am
Simply AWESOME! 8)
PostPosted: Sun Jan 09, 2011 8:12 pm
LSX LUV Owner
dad had a throttle cable layin around. so i made a bracket to hold it at the throttle body and got it all hooked up. dad adapted the end of cable to fit into throttle body.
and another vid. little better quality.
PostPosted: Wed Jan 12, 2011 3:40 pm
Swap Specialist Mod
oh hell yeah man...
thats badass
PostPosted: Wed Jan 12, 2011 5:27 pm
are your gauges all electronically controlled? what gauges are you using if you dont mind me asking.
PostPosted: Wed Jan 12, 2011 10:04 pm
LSX LUV Owner
autometer sport comps
PostPosted: Thu Jan 13, 2011 4:50 pm
Are they analog or mechanical style... in other words does your oil pressure gauge run off a sensor or a oil line. Your water temp off of a sensor or a tempature bung.
PostPosted: Thu Jan 13, 2011 5:38 pm
That is bad ass. I love it.
PostPosted: Fri Jan 14, 2011 12:57 pm
LSX LUV Owner
made it around the block again.
no more air in cooling system
trans is full. shifts good.
still hoping to get maf soon.
brakes dont feel better.
electric sending units
http://www.summitracing.com/parts/ATM-3337/
PostPosted: Fri Jan 14, 2011 6:46 pm
How exactly are they powered is there power running to the sensor in the block or is the sensor powered by the gauge? Just looking at some gauges and doing me up a wish list on summit for tax time lol. Thankyou for your response btw and I am glad to see you be able to get down the road and in style at that. Not much of a nut on bagged trucks but I must admit when you got out and the cab was barely above your hip... I thought that was pretty neat indeed. Looks slick and I cannot wait to see the finished product.
PostPosted: Fri Jan 14, 2011 7:18 pm
LSX LUV Owner
you have power and ground to the gauge, then a wire from the sensor to the gauge as well.
got gas door welded in and bed put on.
PostPosted: Fri Jan 14, 2011 8:17 pm
does he say "2 fat guys in one little truck" ? :lol: :lol:
