It is currently Sat May 09, 2026 7:20 pm
 Post subject: Power by Ace headers
PostPosted: Mon Sep 13, 2010 1:12 am
Has anyone used the power by ace headers?
Hooker
1 3/4 tubes
18 gauge
5/16 thick
$440 from Summit
Power by Ace
1 5/16 tubes
16 gauge
3/8 thick
$380 from Power by Ace
I need to buy some headers. What do you guys think?
 Post subject: Re: Power by Ace headers
PostPosted: Tue Sep 14, 2010 9:21 pm
i've had my hookers for 15 yrs with no problems but it depends on what your plans are for the truck.
PostPosted: Tue Sep 14, 2010 9:59 pm
you should just buy my block huggers :ebiggrin
PostPosted: Wed Sep 15, 2010 12:32 am
Hooker
1 3/4 tubes
18 gauge
5/16 thick
$440 from Summit
Power by Ace
1 5/16 tubes
16 gauge
3/8 thick
You mistyped. The A.C.E. headers are 1 5/8"primarys, under chassis style.
PostPosted: Wed Sep 15, 2010 9:45 am
I did mistype.
I'll probably just end up getting the hooker headers. Lots of people are using them and have had no complaints.
PostPosted: Wed Sep 15, 2010 9:46 am
I might...
PostPosted: Wed Sep 15, 2010 9:55 am
What motor mounts are you using? If you are using the power by ace mounts, hooker headers wont work. I found that out the hard way. I had to go buy the hooker mounts.
PostPosted: Wed Sep 15, 2010 3:38 pm
I might...
after cadams02 made his comment ... looks like block huggers are a damn good idea :ebiggrin
PostPosted: Thu Sep 16, 2010 6:35 am
that's good information. Thank you.
PostPosted: Sun Dec 19, 2010 8:52 am
Glad I read this ALMOST made the same mistake on mounts. Thanks Guys!!!!!
Enjoy, The mouse trap is comming!
PostPosted: Mon Dec 20, 2010 12:39 am
I gotta tell you... the motor mounts are cool. They bolt right up to where the stock ones were.
PostPosted: Mon Dec 20, 2010 7:25 pm
For what it's worth I used the Power by ace motor mtns and they fit perfect and would have used their header but the engine I built needed larger tubes, It's all according to what engine your building and where you want your torque to be. What size tubes is on the block huggers?
