It is currently Mon Jun 29, 2026 11:18 am
PostPosted: Tue Oct 05, 2010 12:59 am
title says it all. what can be expected of a luv with say 350-450hp 4.11 gears th350 stage 2 or 3 shift kit and street drag radials in the 1/4 assuming you can get a decent launch?
PostPosted: Tue Oct 05, 2010 9:14 am
Motor only or a power adder thrown in?
PostPosted: Tue Oct 05, 2010 9:50 am
Wow, when you said "mild" and then followed that up with 450HP, I realized I'm completely out of touch with the racing scene.
PostPosted: Tue Oct 05, 2010 10:04 am
450 is mild... :lol:
PostPosted: Tue Oct 05, 2010 10:12 am
Isn't 450 the first stage of NOS?
PostPosted: Tue Oct 05, 2010 10:14 am
With the small jets...
PostPosted: Tue Oct 05, 2010 11:20 am
Haha sorry guys I guess I've been in the mud scene to long. For the mud trucks we race 450 is mild. I guess for a luv it would be wild. And its all motor no power adders
PostPosted: Tue Oct 05, 2010 2:22 pm
mid to low 11s depending on your traction, and suspension set-up.
A.j.
PostPosted: Tue Oct 05, 2010 2:51 pm
stock suspension, traction bar, 10.5 inch tread width street slicks, 9" rear. thats my proposed setup
PostPosted: Tue Oct 05, 2010 4:43 pm
Mines a mild 383 flat tappet motor. It runs 11.20s on motor and 10.20s on a 100shot. I mostly run the 1/8 tho......
PostPosted: Tue Oct 05, 2010 5:00 pm
Well that's good. It's a grudge match against my buddys c10 with a blown 350. He only turns low 13's. If I cab best him ill be happy
PostPosted: Tue Oct 05, 2010 8:34 pm
Mid 11's to low 12's, I would say...
PostPosted: Tue Oct 05, 2010 9:29 pm
What kind of trap speeds do you get?
PostPosted: Tue Oct 05, 2010 11:43 pm
Man I would have to dig out some time slips but around 94-96 mph in the 1/8 and 122-124 in the 1/4...IIRC
PostPosted: Wed Oct 06, 2010 10:08 am
I've got a mild 565ci (pump gas, hyd cam) that runs 10.0 - 9.9s. @ 131 mph. Same truck with a stock 454 ran 11.85s @ 112mph. Take advantage of the weight. Traction, gearing and leaving the line HARD is were a light vehicle can be surprisingly quick when out gunned in HP.
