It is currently Mon May 25, 2026 11:45 am
PostPosted: Thu Aug 19, 2010 1:41 pm
My '76 project is in terrible shape. The "R" is all over the place. The frame even has corrosion. Time and money being what they are I know its going to take a long time to restore it and I want to stop it in it's tracks. I figured where better to go than to reach out to you guys for advice. Has anyone tried a "rust stopper" with any success? I'm no hot-rodder at all, in fact this will be my first restoration so I'm having to learn as I go. If you guys can point me in the right direction I would greatly appreciate it. Many thanks.
James Bates
PostPosted: Fri Aug 20, 2010 7:31 pm
por-15... kinda pricey but it is the shit...
PostPosted: Mon Aug 23, 2010 5:39 pm
Thank you Jeremy. I'll check it out.
James Bates
PostPosted: Mon Aug 23, 2010 7:33 pm
sure thing man... like I said its kind of on the high side but it works and you cant knock the shit off with a hammer
PostPosted: Tue Aug 24, 2010 5:10 pm
Wow you wasn't kidding about pricey huh? Looks like a solid product though.
James Bates
PostPosted: Tue Sep 21, 2010 5:12 pm
sorry long time to respond... it is good stuff indeed... I used it on my frame and am very highly satisfied with it
PostPosted: Tue Sep 21, 2010 5:46 pm
No worries mate! I'm honestly just trying to learn the proper way to go right now. Very little funds + very little time = not a lot of LUVin' getting done!
James Bates
PostPosted: Tue Sep 21, 2010 6:57 pm
I understand that man. Funds for sure will hold a man back. I went on deployment and thats were I got all my funds from lol.
PostPosted: Wed Sep 22, 2010 8:36 am
spray paint then grind it or blast it off later
PostPosted: Wed Sep 22, 2010 12:52 pm
What I have used in the past with good results on both my Luv & my '62 Chevy is a rust converter in a spray bottle. You can buy it in any auto parts store, but be damned if I can remember the name of it. Its green, stinks like rotten eggs and is in a spray bottle. You just hose down the rusted area with this stuff and wait about 2-4 hours. Converts the rust to grayish black that you can then prime and paint over. I have not had any rust bleed thru on anything I have used this on in the past 3 years.
I think its only about $6-7 bucks a bottle and that might work for you if money is tight.
I have'nt had to use any in the past year or so, so I don't have a bottle lying around to get the name of this stuff, but if I remember it, I'll post it.
1990 Chevy Suburban
PostPosted: Wed Sep 22, 2010 4:56 pm
If you can think of it maduro let me know. The next time I'm in the parts store I'll look it up. Thanks for the heads up!
James Bates
PostPosted: Wed Sep 22, 2010 10:32 pm
I used Eastwood products to COMPLETELY rebuild my 80 4x4. I was very satisfied with their rust converter products.
1980 4X4 LUV
PostPosted: Fri Oct 01, 2010 3:01 pm
About corrosion on the frame. Make SURE you check behind the rear cab mounts on the frame. They are notorious for rusting the frame completely in two! I know a guy whos rusted and broke apart. Imagine his surprise!. I rebuilt my 80 4x4. The frame only had rust at these mounts. I had a professional welder section the frame with very stout c-channel and built the cab mounts. He did a wonderful job.
1980 4X4 LUV
PostPosted: Fri Oct 01, 2010 3:25 pm
Thanks for the heads up Rick. I've actually got the bed off right now working through a fuel delivery issue. I'll take a look! Yeah it wouldn't be nice to be driving down the road and have it split into like some kinda James Bond movie! :esurprised
James Bates
PostPosted: Sat Oct 02, 2010 11:01 pm
I have used the following products with success.
Blulightning
POR 15's Metal Ready
Honestly I prefer the blulightning but the por 15 is easier to get locally.
Best of luck,
Eric Q.
My build thread.
