It is currently Mon Jun 08, 2026 1:40 am
PostPosted: Fri Jul 02, 2010 1:37 pm
there are the ten head bolts and then the two little ones by the timing gear that hold the head down.... I have a neverending slow oil leak coming from there and I cannot get it to stop... I have tightened the bolts but cannot find a exact torque spec for those two bolts... makes the engine look crumby and burning oil is not a desired smell while drivin... any suggestion on how to get this leak to stop?? Thanks guys
Jeremy
PostPosted: Fri Jul 02, 2010 2:34 pm
I looked for the torque for the two bolts...from the head to the front cover and I can't find it in my shop manual. IT points these two bolts out in the head torque sequence (that's what I was doing at the time) but I have a hard time believing they get torqued to 70 ft lbs. 8O I', thinking if they are tight you might be looking at a gasket replacement.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Fri Jul 02, 2010 5:48 pm
I just replaced the head gasket... it just slowly leaks oil from there... they cant go past twenty before they twist off... I learned this the hard way unfortunately....
PostPosted: Fri Jul 02, 2010 5:56 pm
They are called "front cover fixing screws". They are 8mm, same as the rocker arm studs, should torque the same, 14 to 16 ft-lbs.
PostPosted: Fri Jul 02, 2010 10:00 pm
thankyou... I learned something new today after all lol
PostPosted: Sat Jul 03, 2010 1:15 am
Oil will leak from the small crack where the block and timing chain case join together. The fix is a dab of sealant, (permatex or gasket sealer of some type) applied there before you put on the head gasket. Some repair manuals will tell you about this and some do not. Has worked great for me.
PostPosted: Sat Aug 21, 2010 8:05 pm
hey egg... thankyou... worked like a charm... no more leak
PostPosted: Sun Aug 22, 2010 12:39 am
BTW- a tip on torqueing bolts to less than 20 ft-lbs, the lowest reading on most clicker torque wrenches: get & use an inch-pound clicker wrench, to convert divide ft-lbs by .083 to get in-lbs.
With the bolts talked about above 15 ft-lbs/.083 = 181 in-lbs.
PostPosted: Sun Aug 22, 2010 10:16 am
wow... never knew that... now you just gave me a reason to go get another torque wrench just to have it around... thanks isuzuiest
Users browsing this forum: Bing [Bot] and 55 guests
