It is currently Sun Jun 07, 2026 11:18 pm
 Post subject: brake issues...
PostPosted: Wed Jul 21, 2010 10:11 am
I've got a 79 Mikado that likes to lock up the front left brake. I've tried switching out calipers with the same result. Step on the brakes, the piston will compress but will not return resulting in a locked wheel. Naturally, this is pissing me off. Any ideas?
"...personal enlightenment usually begins and ends with beer."
 Post subject: Re: brake issues...
PostPosted: Wed Jul 21, 2010 1:51 pm
I would replace the brake hose on that side. Since you are doing one side, its a good idea to go ahead and do the other side as well.
1990 Chevy Suburban
PostPosted: Wed Jul 21, 2010 8:07 pm
x2...
PostPosted: Wed Jul 21, 2010 8:11 pm
If that doesn't do it, you might have a master cylinder problem. That happened on my '81.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Thu Jul 22, 2010 10:59 am
thanks gents. advice well received.
