It is currently Mon Jun 08, 2026 1:27 am
 Post subject: Door repair
PostPosted: Mon Jun 21, 2010 9:14 pm
Ok.I posted a couple of days ago that my drivers door hinge locked up and I bent my door! What if I take the door off and straighten the bend and reinforce it with a piece of steel? I know I would have to use longer bolts for the hinge. Or are the hinges spot welded onto the door?
I haven't taken the door panel off to see if it is possible. Any ideas or advice?
 Post subject: Re: Door repair
PostPosted: Mon Jun 21, 2010 10:00 pm
We just replaced one on my son's '80 Luv and they aren't welded on. When you talk about reinforcing it, do you mean from the inside of the door?
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Tue Jun 22, 2010 6:55 am
Yes the is what i thought because that way the reinforcement would be on the whole side of the door and you wouldn't interfere with the hinge.Only problem I think of is the pain in the butt it will be to realign the door.I can paint, do some bodywork, but I HATE body panel alignment!
PostPosted: Tue Jun 22, 2010 4:10 pm
Panel alignment....if it won't align the way it's suppose to then a few shims and if need be a grinder and welder. IT CAN BE ALIGNED.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Tue Jun 22, 2010 9:46 pm
By the way dog trainer, I am from SD and I must say that is a fine looking dog.From the pic looks like Brittany.If you pheasant hunt pm me and I can give you details to go!
PostPosted: Tue Jun 22, 2010 10:27 pm
PM sent!
1981 Luv 2WD
1981 Luv parts trk
