Joined: Sat Jul 12, 2008 12:43 pm Posts: 497 Location: Upland, CA
Hi All,
Bought a Weber 32/36 DGV 5A kit from Redline, trying to do the prep for the install. I read through the post from Fullaluv, his install seemed pretty standard. Anyway a few specific questions for the Weber gurus on here ---
-Fuel pressure. I have a 72, I haven't put a gauge on it but the manual says the mechanical pump gives 3.13 PSI. One source I read said maximum 3 psi, the install sheet says if you regulate it to 2 you'll be better off. I bought the Holley 1-4 PSI regulator, intending to regulate to 1.5 or 2 psi but it looks like it'll be tough to mount it and now I think I'm realizing that to regulate to 1-4 PSI you need to probably have about 6 or 7 PSI.
-Throttle linkage. My truck has a series of levers and pivots, not a cable throttle like the later Luvs (72 truck). I think everything will transfer, but has anyone done this?
-Phenolic spacer. Should I use it?
-Float level. You can't see it through the window like the Hitachi. Anybody have trouble getting theirs set?
Joined: Thu Jan 13, 2005 11:51 pm Posts: 465 Location: So Cal
eln1972luv wrote:
Hi All,
Users browsing this forum: Bing [Bot] and 17 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
