It is currently Mon May 25, 2026 8:17 am
 Post subject: back half my 72
PostPosted: Wed Apr 28, 2010 11:15 pm
i just got a 72 luv and i want to back half my truck. does anyone know which frame rail kit i should get and if im gonna have to do major mods to make it fit? thanks
 Post subject: Re: back half my 72
PostPosted: Thu Apr 29, 2010 12:45 am
so when are we going to take it apart...
SALINASRACING.COM
PostPosted: Thu Apr 29, 2010 7:14 am
http://autoweldchassis.com/frames.ivnu
LUV PICKUP
Rear Frame Clip
Includes: Jig welded frame,
"Low Profile" pro-street 4-link,
series 7000 coilovers, panhard
track locator, rod ends.
Very complete!
Part #3570......$1449.00
NEW! Fixture welded 9" Ford housing
with all brackets located...add..$699.00
Moser race axles
(up to 35 splines)....$340.00
Bearings,1/2x3 studs, retainers
add...................$99.00
PostPosted: Thu Apr 29, 2010 9:54 am
As soon as i get some time an some money an parts prettysoon
PostPosted: Thu Apr 29, 2010 5:58 pm
thats a nice! rear clip,and the price is not that bad
SALINASRACING.COM
PostPosted: Fri Apr 30, 2010 11:16 pm
Save you over $1k to buy material and build it yourself man!
PostPosted: Wed May 05, 2010 11:05 am
For racing or just lowering?
PostPosted: Wed May 05, 2010 11:54 am
Just for your info i used another set of frame rails from a parts truck to narrow my truck. Sorry i don't have pic's of the complete frame but i do have some from underneath that could give you an idea keeping in mind that it was built for heavy street use but can be lightened for racing(maybe 20-25 lbs).
PostPosted: Wed May 05, 2010 11:59 am
This is just so you can get an idea for your project.
PostPosted: Fri May 07, 2010 6:31 am
Thanks everyone. I want to back half it for racing purposes. Ill probly end up building my own back half but its always good to have second opinions aswell as more ideas and would greatly appreciate pictures. Thanks
PostPosted: Fri May 07, 2010 1:44 pm
Good luck, and post pic's on the build.
PostPosted: Sun May 09, 2010 7:06 am
Yes good luck on your build and keep us posted.
JFYI on my truck i did it for the street with no cage but once a cage is installed the inner frame rails can be removed to save weight. I did it this way to stop twist and it worked.
