It is currently Mon May 25, 2026 9:48 pm
PostPosted: Tue Mar 30, 2010 11:26 am
I was wondering if anyone had tried or could tell me if the rear disc hubs from one of the 80's model Troopers could be swapped into my '84 differential? Trying to economically get away from the drums for simple ease of maintenance.
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Tue Mar 30, 2010 8:44 pm
It will come down to what it will take to get the mount bracket off the Trooper rear to your housing and then machining may be necessary of the axles to fit the rotors.You can also make your own mount brackets to if necessary.
PostPosted: Tue Mar 30, 2010 10:15 pm
You might fab it all up & get it to fit, but it would be really costly. Rear disc Troopers only came with Isuzu 12-bolts, every thing about them- axles, axle tube- is much larger than the 10-bolt in your truck, so nothing will bolt on without modification.
PostPosted: Wed Mar 31, 2010 11:47 am
That's what I was afraid of. The aftermarket kits are ridiculously expensive and they're 5-lug, so I guess I'll have to persue another option or just deal with the drums.
PostPosted: Wed Mar 31, 2010 7:48 pm
Just a thought but if you can find and measure the Trooper rotors and if they are or close to a .990 measurement then you can use the GM metric calipers and then Speedway has a large selection of mounting brackets.
