It is currently Sun Jun 07, 2026 11:32 pm
 Post subject: Fuel pump?
PostPosted: Thu Mar 18, 2010 12:48 pm
Where is the fuel pump located? my auto teacher says it should be in the tank.
2006 GMC Sierra 2500 HD
 Post subject: Re: Fuel pump?
PostPosted: Thu Mar 18, 2010 1:08 pm
Look on the back side of the last crossmenber on driver side
PostPosted: Thu Mar 18, 2010 1:26 pm
It is on the crossmember in front of your gas tank, sounds like your auto teacher needs to go back to school and learn about older non fuel injected vehicles.
PostPosted: Thu Mar 18, 2010 2:37 pm
The LUV might be older than the teacher :lol:
PostPosted: Sat Mar 20, 2010 9:03 am
Does it matter what kind of pump it is or can it just be any electric fuel pump
PostPosted: Sat Mar 20, 2010 5:56 pm
Depends on your setup. Different carbs require different PSI, so if you get a non-stock fuel pump you'll have to get a regulator to reduce the PSI to the proper level unless it is already rated for the application you need. For example, the Webers need on or under 4 PSI if I remember right and the Hitachis need around 7 (correct me if I'm wrong, anyone). The stock pump puts out enough PSI for the Hitachi but I've have to add a Holley 4 PSI regulator (I've heard some people just adding additional fuel filters) to keep the carb from flooding out.
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Sat Mar 20, 2010 7:46 pm
When my original went bad, I bought the first of several replacements at Parts America. Finally after about 4-5 of them, they didn't have more junk in stock and the kid offered me a generic one. I grabbed it and ran. Maybe been 10+ years and it is still doing fine. My 77 has a return line keeping the pressure very low. The float valve should cope with different pressures.
Users browsing this forum: Baidu [Spider] and 52 guests
