It is currently Sat Jun 27, 2026 10:54 pm
 Post subject: FUEL TANK QUESTION?
PostPosted: Fri Feb 26, 2010 10:47 am
HOW DO I GO ABOUT CLEANING MY GAS TANK AFTER THE TRUCKS BEEN SITTING FOR A COUPLE YEARS?
 Post subject: Re: FUEL TANK QUESTION?
PostPosted: Fri Feb 26, 2010 10:54 am
whatever you do, DO NOT light it on fire. did that on accident once.
PostPosted: Fri Feb 26, 2010 11:21 am
on a more serious note, i've heard of guys using Sea Foam
PostPosted: Fri Feb 26, 2010 12:44 pm
what is sea foam? i helped my uncle do motorcycle tank mith some chemical ho bought i guess it was to recondition it but im not sure for my truck? and yeah i dont think gas tanks and fire is a good combo. :lol: hope nothing bad happend.
PostPosted: Fri Feb 26, 2010 2:18 pm
well my dad would clean his side tanks on his truck about every 5 years. It was quit the process.
First he would presure wash them in and out.
Then to get the water out he would rinse the tanks out with diesel.
To get the diesel out he would rinse them with gas.
I don't know if this was the right way but it works. We also had a big burn pile to dump the the cleaning fuel on.
PostPosted: Fri Feb 26, 2010 2:31 pm
Take it to your local radiator shop...
PostPosted: Fri Feb 26, 2010 3:04 pm
For the DIY
link>
http://www.eastwood.com/ew-gas-tank-sea ... -cars.html
Gas Tank Sealer Kit For Cars
Item #10165 Z
Suggested Retail Price: $0.00
Only $49.99
Seal Your Tank For a Cleaner Fuel System
Seal minor leaks and skip a tank replacement
Save time and money!
Use with Metal Wash, Fast Etch, and Sealer for an impenetrable seal
You will need to purchase Muriatic acid from your local hardware store to clean the tank. The acid will need to be diluted 20:1.
Quote:
A clean supply of fuel is critical to the performance of your vehicle - hard starting, stumbling under load, and sluggish response may be symptoms that your car's fuel system is dirty. The best way to ensure that the fuel is clean is to be certain that the fuel tank is free of rust. This Gas Tank Sealer Kit seals minor leaks and can save you a great deal of time and money in trying to locate a replacement tank. For metal tanks up to 20 gallons. Kit contains one 7 oz. can of Metal Wash, 1 pint of rust remover, two 16 oz. bottles of Gas Tank Sealer. Tank Tone (10030Z) resembles the original finish.
PostPosted: Fri Feb 26, 2010 7:57 pm
Ethelkilledfred has a great idea. I cleaned the tank on a 1973 MG Midget I had and it leaves a nice clean surface on the inside. You can recoat it for better protection if you want. I don't know how close the fuel pickup tube is to the bottom of the tank, but you might blow a bit of air through it once in a while while drying. The one in my Midget was close enough to the bottom that it actually sealed it, preventing gas from being drawn up. It was a pain to fix! Also, the first step I did was to put a handfull of large nuts in the tank, suspend it from my garage ceiling with bungee cords and rolled, shook, bounced, etc. This breaks loose severe rust. Then I used the kit.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat Feb 27, 2010 1:31 pm
hey thanks guys for the imput. good idea on loosening the rust inside of the tank.
PostPosted: Sat Feb 27, 2010 3:18 pm
Chain and even rocks work... I always used chain... you do not have to count the number of bolts and huts to see it you got all them out.
Like mytmouz said. Local radiator shop.
PostPosted: Sat Feb 27, 2010 8:10 pm
yeah thats true. and is it cheaper to take it in to a shop? that sounds good that way they can check the radiator out too.
PostPosted: Wed Mar 03, 2010 1:04 pm
Took mine to Radiator shop cleaned lined and sealed for less then $100. Well worth it to me drop off pick up... No fumes or freaking mess to deal with call one and see what they will do worth a shot before messing with it....
PostPosted: Thu Mar 04, 2010 12:30 pm
yeah your right im gonna make some phone calls. thanks
Users browsing this forum: No registered users and 81 guests
