It is currently Fri Mar 27, 2026 8:24 pm
PostPosted: Sun Feb 14, 2010 3:08 am
So uh, my wheel cylinder exploded.
Yeah.
I'm not too happy about that. :evil:
The brake shoes are SOAKED in brake fluid, and now i've got a decent sized puddle under the rear driver side tire. Not only that, but I have to special order my brake shoes. How stupid is THAT? :twisted:
Some pictures.
Walked out to the truck to warm it up before we left and saw this puddle under the tire. At first i thought it was water from melted ice or something, but a double check told me it was brake fluid.
I'm hoping to have the brake shoes in on monday morning. if not, that means Jekyll/Hyde is going to be down for a few days... And just when i was planing to
BTW, I found a name for my truck...
PostPosted: Sun Feb 14, 2010 9:16 am
Not that I would ever do this again but I had a problem similar to that years ago on an old Chevy truck I had. I am a believer in never "Skimp" on steering and stopping components but at that time I was a young airman in the Air Force and TOTALLY BROKE so I kept my brake shoes and cleaned the hell out of them with Kerosene. Never had a problem. If you need the truck NOW it might be an option until the new shoes come in. I know, I'll get some criticism for how unsafe this is but it helped me out in a pinch when I HAD TO HAVE the truck.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Feb 14, 2010 11:24 am
A young Airman in the Air Force that's broke? :lol: Been there (with two kids too) and done that!
Just to add, I did the same thing with cleaning but followed it up with a wiping with denatured alcohol to remove any left over kerosene.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sun Feb 14, 2010 12:21 pm
well, i do have the wheel cylinder rebuild kits, so at least for now, i will get those done so that i can get the brakes done early monday morning
PostPosted: Sun Feb 14, 2010 2:03 pm
If you are real desperate and no shoes wash the shoes in hot soapy water then rinse i hot water as any petroleum product is a absolute NO-NO.
Keep in mind that brake fluid is a detergent and is water soluble not petroleum (solvents) soluble.
PostPosted: Sun Feb 14, 2010 2:23 pm
hmmm, i didnt think about that. i'll have to give it a try and see what happens. i just sent the wife to get the new shoes anyway as i might as well get them replaced and get it over with. But, yeah i'm just hoping that at least ONE option is available...
PostPosted: Sun Feb 14, 2010 4:20 pm
The mechanics at work have cleaned them up (gear oil) with brake cleaner instead of replacing them.
PostPosted: Mon Feb 15, 2010 12:49 pm
Hey, does anyone know what brand of brake components were factory issued for the Luv trucks?
When i cleaned them up, i found an "Akebono" stamp on them. Is that the OEM brake shoe manufacturer? 8O
I cleaned the shoes like Tj said, and they look like it could do the trick and i can put off replacing them for a few months.
So far, one wheel cylinder is done, and i'm debating, (or rather im trying not to be lazy) whether i should bother rebuilding the other side while i'm at it. but it's cold outside, and rainy.
PostPosted: Mon Feb 15, 2010 1:02 pm
Do both sides...
PostPosted: Mon Feb 15, 2010 1:25 pm
But MAAAAAAAA! It's RAINING!
(*grumbles* FINE! *grumbles*)
Stomps out of the house....
PostPosted: Mon Feb 15, 2010 8:55 pm
ok ok, i'm glad i did take a look at the other side. the wheel cylinder there was starting to fail.
one side is done, but i'm planning to flush the brake lines and re-bleed the master cylinder with fresh fluid. hope i will be done tomorrow...
PostPosted: Mon Feb 15, 2010 8:58 pm
You made the right choice...always do both sides if you can.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Mon Feb 15, 2010 10:01 pm
You should allways do them in pairs.
PostPosted: Mon Feb 15, 2010 10:03 pm
i know i should. i'm just lazy today. feeling rather sick and nauseous...
PostPosted: Mon Feb 15, 2010 10:10 pm
Preggers?
PostPosted: Mon Feb 15, 2010 10:40 pm
If i am, im in trouble! I dunno who the father is! :lol:
PostPosted: Mon Feb 15, 2010 11:51 pm
Is it someone from LUVTRUCK.COM? You do sign off sometimes as "earning your GURU status"!! :lol: :lol: :lol:
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Tue Feb 16, 2010 12:12 am
i dunno.... I met a few luvtruckers' while i was down there.... :?
i really should change that huh?...
PostPosted: Tue Feb 16, 2010 10:21 pm
well,
dad came over and helped me bleed the brakes.
kept questioning my every move. i told him we needed to bleed the master cylinder first, but he kept asking why...
anywho, here is a good question that i'm having trouble figuring out.
when installing new shoes, you have to take the adjusting rod at the bottom down to zero right?
i did just that, and had a HELL of a time trying to fit the drum over the new shoes. i couldn't turn the trum AT ALL.
i'm used to the older 70's chevy brake systems, so is it that it just needs to be driven for a bit and it will be better?
also, i know these brakes are supposed to be "self-adjusting", but i'm not too sure how it works. anyone care to explain?
PostPosted: Wed Feb 17, 2010 7:32 am
i found that out the hard way, to so both sides of mainly all steering and stoping components.
80 Chevy LUV 4x4
Users browsing this forum: No registered users and 61 guests
