It is currently Mon Jun 08, 2026 1:48 am
PostPosted: Tue Feb 02, 2010 5:29 pm
CT'S LUV wrote:
well i finally went and got the fenders the other day but they weren't n.i.b. but not bad, paid 125 for them.
one's in good shape the other needs some work here are a few pic's......just need to find the steps to go with these now.
this one needs work but i have a hook up on body work.
Looks like you made out good...
PostPosted: Tue Feb 02, 2010 6:34 pm
nice... been trying to find me a pair like that to make copies of the flare on them... they made the luv ones with that flare as an option but have never found a set, yet...
PostPosted: Tue Feb 02, 2010 6:42 pm
Mine has a flair, and looking at the steps I have, the full size ones are too big, distance from step to cab) may can be cut down...
PostPosted: Fri Feb 05, 2010 12:02 am
There were at least two companies that did the step side conversion in the beginning. Cal Step Side located in Cal and a company by the name of Anderson from the south. Cal step side copied the big chevy step side fenders and Anderson copied the Ford rounded step side from the 60's.
Could that flared fender be copied from the dually rear fenders.
I believe all of the aftermarket kits had a metal step separate from the fenders. It would support more weight.
I have a set of cal step side fenders and bed, however the crossmember are welded in for a pl620 datsun.
PostPosted: Fri Feb 05, 2010 12:53 am
there where 3 companies, cali, anderson and one other but dont remember there name... andersons used the early ford and chevy fenders, cali was the later chevy fenders
here is on the cali and anderson... the other came in late in the game and wasn't mentioned here...
http://www.luvtruckin.org/resources/stepsideinstall.pdf
PostPosted: Fri Feb 05, 2010 4:15 pm
this is some god info guy's, wow 395.00 for a stepside set up...... that's a deal in my book.
PostPosted: Fri Feb 05, 2010 4:56 pm
wish i had those fenders, i am contemplating cutting the steps on mine for my custom exhaust idea.
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Fri Feb 05, 2010 8:30 pm
i have a set i will trade you for they just dont have the flare...
PostPosted: Sat Feb 06, 2010 10:26 am
i might have to do that. i just cant bring myself to cutting these
zyanug
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Mon Feb 08, 2010 11:05 pm
What are you going to do with those? Put those on your truck? That would mess your purdy yellow paint job up :cry:
PostPosted: Tue Feb 09, 2010 5:32 pm
yes sir papaG.......
i have a guy that is going to work them a bit then we will prime and paint, gonna do a cage install in the truck and from there we are going to do the body work and repaint yellow..... :D
PostPosted: Wed Feb 10, 2010 10:14 pm
Cool.. Can't wait to see the build pics- finished truck.
Users browsing this forum: Google [Bot] and 38 guests
