It is currently Sun Dec 21, 2025 6:16 am
 Post subject: need some help
PostPosted: Sun Sep 07, 2003 8:57 pm
does anyone know if the torsion bars out of an isuzu trooper will fit 72 luv?
 Post subject: torsion bars
PostPosted: Sun Sep 07, 2003 9:42 pm
I ahve no idea if they will fit form an izuzu or not.I have 2 parts trucks if you need torsion bars I have them.
PostPosted: Wed Sep 10, 2003 8:14 pm
Hmm... I can tell you one thing, the 84-86 troopers have an almost identical suspension setup as my 79 LUV. Now if you can find someone to tell you whether or not the 72 suspension is like my 79, you're all set. If it is then I can assure you that a ton of the suspension parts will fit.
PostPosted: Thu Sep 11, 2003 8:50 pm
yes, they look identical the thing is on the v6 trooper there a little bigger around but the ends look the same size so i think it would be nice to have them with all that extra wieght from the v8, im gonna get them with in the next 2 weeks, i will put a new post up for u all on whether or not they fit
PostPosted: Thu Sep 11, 2003 8:56 pm
Thanks, keep us posted. :)
PostPosted: Thu Sep 18, 2003 10:51 am
I've heard of 4x4 trooper guys/gals swapping in the smaller 2WD Isuzu PUP bars in order to get better suspension travel from stuffed to droop. There was quite a bit of difference in the suspension on the 2WD LUV from 80 to 81, but I believe the bars still have the same ends splines.
PostPosted: Fri Sep 19, 2003 9:00 am
Japanese Redneck
I dont think swapping torsion bars is going to give you any more travel on the suspension. You can crank stock bars up until the control arms are as far down as they can go. Pu'P bars may give it a better ride when its cranked up all the way though.
PostPosted: Fri Sep 19, 2003 9:42 am
just put oval wheels on there....when you get to the large part you will have enough travel to get you over your obsticle.....hehe
03Cobra
