It is currently Mon Jun 08, 2026 1:48 am
 Post subject: luv will not run
PostPosted: Tue Jan 12, 2010 3:46 pm
I drove the luv yesterday and it ran fine but this morning i hit the key it fired up and died as soon as i let go of the key i have worked on it all day same result never have had this problem before could it be the ign switch?
 Post subject: Re: luv will not run
PostPosted: Tue Jan 12, 2010 5:34 pm
so, i'm assuming that the engine is cranking, that tells me one of two things.
one, there is a possibility that you have a loose wire either at the coil or coming from the starter.
or two, (and i had this problem) your points are welded. check them and make sure they aren't welded shut.
let us know if this helps!
PostPosted: Tue Jan 12, 2010 5:43 pm
Alternator working? No battery charging means no fuel pump operation.
PostPosted: Tue Jan 12, 2010 5:58 pm
engine cranks starts right up dies like you turn the key off when key goes back to on position has good power to the coil and has good power to dist. until you turn the key loose i will check points in the morning
PostPosted: Tue Jan 12, 2010 6:04 pm
these switches do wear out and do some funny thing at times... try hot weiring it and see if it does the same thing or if you have a friend around with a luv swap switches and see. takes 2 min. to do,,, just an idea
PostPosted: Thu Jan 14, 2010 5:40 pm
luv is now fixed it was the ballest resistor :smt023
PostPosted: Thu Jan 14, 2010 6:22 pm
good to hear you got it going
PostPosted: Thu Jan 14, 2010 6:57 pm
lxconvertable - stumbled across this thread because my luv died this morning
I've seen your luv in so many times online and its nice to see the person it belongs to on here ... I love it!! I am almost inspired to convert mine (if only I had the money and skills to do it)
PostPosted: Mon Jan 18, 2010 2:39 pm
Where is the ballust resistor?
PostPosted: Mon Jan 25, 2010 4:24 am
It's mounted on the coil-
PostPosted: Mon Jan 25, 2010 10:32 am
$20.00 at autozone
PostPosted: Mon Jan 25, 2010 11:38 am
I have the same problem I'm going to try that and see if it will work :ebiggrin
2006 GMC Sierra 2500 HD
PostPosted: Tue Jan 26, 2010 2:58 pm
good luck i hope that does it
i even had a better idle speed after i replaced it
Users browsing this forum: Google [Bot] and 41 guests
