It is currently Fri Feb 06, 2026 1:41 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: florian... LUV?
PostPosted: Thu Apr 30, 2009 11:04 am
OzLuvTrucker wrote:
Hows about fiting two luv cabs back to back on a modified Luv frame. Somthing like in the pic below.
Now if you could set it up to drive either direction, have a 4 cylinder for one and a V8 for the other. That would be having your cake and eating it too. You would also increase business for the chiroprators from all the next strains from double takes people would be doing. :lol:
PostPosted: Fri May 01, 2009 7:31 am
Maybe we can pick up a couple of those Florian's and ship them home and then build some nice crew cabs .
PostPosted: Sun May 17, 2009 5:39 pm
I actually saw an old Mini Cooper welded back to back and looked very different. The rear steering wheel was locked in place, but could be unlocked to screw with people I guess. The LUV would be interesting! Close off the rear engine compartment and you would have a backward opening trunk. Just don't get drunk and try to figure out which end is FRONT! :lol: (I do not drink and drive). Title and license would probably fall under kit cars. I looked into that while in Las Vegas as I had a LUV chassis from one year, cab from another year, engine from a different vehicle, rear end assembly from yet another type vehicle, etc. etc. They said it would fall under the general title of KIT but would be given the name I requested, ie LUV truck. Don't know how other states work or what changes have been made to these ever changing laws. A guy there designed built a car that looked like the stealth fighter, and drove it enough to where I saw it several times, and it was licensed as the STEALTH.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sun May 17, 2009 11:02 pm
rgw double cab thing was my initial idea, but after measuring it all up the wheel wells would come about 6 inches into where the door jambs are
PostPosted: Wed Dec 09, 2009 11:14 am
On what chassis?? The SWB one.
Get a LWB chassis. From under an 85 and drop the cab on that.
Neither the sedan or the wagon had a cutaway in the door frame to allow for wheel base. The Luv?KB just happens to be short in SWB form.
Geez its hard work trying to find pictures of a Florian wagon. Imagine how hard it would be in the flesh to find one to eyeball.
Bob.
PostPosted: Wed Dec 09, 2009 12:29 pm
Several VW Rabbit Trucks have been done. Even some have been done using the Jetta front end....
The good ones the rear doors correct and not for a rear fender on the back side of the door.
PostPosted: Wed Jan 13, 2010 7:37 pm
Bob.
whats the dash in one of those look like
Epic Fabrication.
KAOS
PostPosted: Wed Jan 13, 2010 7:57 pm
PostPosted: Wed Jan 13, 2010 8:00 pm
trip odomer. in that last pic . cooollllllllll
PostPosted: Wed Jan 13, 2010 8:13 pm
i just want this front end to put on one...
PostPosted: Wed Jan 13, 2010 8:31 pm
There is a pink one on this site somewhere with that front end but I cant find it. :twisted:
Nevermind, found it, it has the luv curve to the front not straight acoross like the florian though.
http://www.luvtruck.com/Gallery/NaokiNakamuras75YokohamaJa/DSC00713.html
PostPosted: Wed Jan 13, 2010 11:45 pm
yep , that guy in japan just used the grill and lights only
PostPosted: Mon Jan 18, 2010 1:42 pm
couldnt we jus use the dash pad outta one of t hose to replace the one in the luvs with? or are they as hard to find/buy parts for as tha luv
Epic Fabrication.
KAOS
PostPosted: Mon Jan 18, 2010 6:44 pm
yes you could but.... 10 times harder to find parts for then the luv....
PostPosted: Tue Jan 19, 2010 6:37 am
wellp their went my idea
Epic Fabrication.
KAOS
