It is currently Wed May 27, 2026 12:14 am
 Post subject: Timing...
PostPosted: Thu Jan 07, 2010 8:10 pm
What should I set the timing at on my 76 LUV? It has electronic ignition on it from a 80 LUV though. Not sure if that matters or not. Thanks!
 Post subject: Re: Timing...
PostPosted: Thu Jan 07, 2010 10:39 pm
In 25 years of driving Ive only had three or maybe four (not sure about a 1976 toyota corona 20R) cars with electronic ignition. Rockcharger.com tech articles how to adjust ignition timing. Those three or four cars I never had to set or adjust timing. The eighty had points.
1980 4x4
PostPosted: Thu Jan 07, 2010 11:23 pm
It should be the same as the points set up. I think it's 6 or 8 btdc. Or, where it runs nice and doesn't ping.
PostPosted: Fri Jan 08, 2010 12:35 am
Just checked the book, and it lists it at 6* BTDC @ 900 RPM
PostPosted: Fri Jan 08, 2010 12:50 am
if you did put electronic ignition in a 76/80 it should be set at around 10* to 12* BTDC... thats the way i have set up the 3 i did and they seam to run better that way
PostPosted: Fri Jan 08, 2010 2:41 am
lol, 1980 LUV's didn't come with electronic ignition, so if you go to the parts store, ask for an 1981.
PostPosted: Fri Jan 08, 2010 10:48 am
Oh ok it must have been off a 81 then. I was thinking 10* so we will see how that works. It just doesnt have the power it used to. I think its because of the massive exhaust leak though lol.
PostPosted: Fri Jan 08, 2010 10:51 am
10 to 12 is what i have been told and i think the last 2 including mine i have set at 12* seems to run well there
Users browsing this forum: No registered users and 55 guests
