It is currently Mon Jun 08, 2026 6:47 am
 Post subject: smog pump hose
PostPosted: Mon Nov 23, 2009 8:58 am
I have to get my 78 to pass smog. The smog pump hoses were all rotten. I pulled them off. I am having a prob finding replacements for it. I used some radiator hose but it binds in the middle and doesn't flow correctly. I will take the pump off when I pass but, for now I need it to all look stock..
Any advice would be greatly appreciated.
 Post subject: Re: smog pump hose
PostPosted: Mon Nov 23, 2009 10:16 pm
dang, no help?
PostPosted: Tue Nov 24, 2009 12:46 am
where are you located. How many do you need....all of them? I can look at my parts Luv and let you know what mine look like. If they are good, you can have them for the cost of shipping.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Tue Nov 24, 2009 3:33 am
lol, if they don't look good, wrapping them with a good cloth based tape always works.
PostPosted: Tue Nov 24, 2009 9:10 pm
they were thrashed, so I tossed them. I live in Vegas and would be happy to pay shipping on some hoses.
PostPosted: Tue Nov 24, 2009 10:59 pm
Let me take a look at the ones on my junk truck and I will let you know. Will try to get on that in the next day or so.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Thu Nov 26, 2009 10:58 am
I just took the pump off. My friend had his 79 C10 pass smog with out a smog pump and 2 leaky mufflers. He feels that my truck will pass without them as well.
PostPosted: Thu Nov 26, 2009 11:59 am
I think mine will probably be OK. Let me know if you want me to pull them or not.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Thu Nov 26, 2009 5:53 pm
thx, I appreciate your offer. I will let you know if the dude won't let me pass.
PostPosted: Fri Nov 27, 2009 4:26 am
Uh, the going to the smog shop is a no-go without everything attached... if they run you, and you don't pass because you don't have all the stuff hooked up, you'll be put on the list for a smogging every time your registration comes due.
I'd hook everything up before you go in.
PostPosted: Fri Nov 27, 2009 9:36 pm
really, I hope not. I kept everything I took off. However it will suck putting it all back on. My friend said his truck ran like crap and had all the smog equip taken off. Well, wish me luck... I guess
PostPosted: Fri Nov 27, 2009 10:17 pm
If you're going to try and pass emissions test without it make sure it's running top notch. Maybe even a tune up and definitely tune the carb. If you're having issues with it go lean over rich for the test. Good luck with whatever way you go.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Sat Nov 28, 2009 12:45 pm
thank you sir, what my friend told me today is that pre 1980 in nevada vehicles didn't need smog pumps. My truck was from cali where it did and still does. So, if he is wrong I will flog him.
Users browsing this forum: Majestic-12 [Bot] and 56 guests
