It is currently Wed Jul 01, 2026 4:50 am
 Post subject: shory headers?
PostPosted: Sun Oct 25, 2009 10:17 am
Im on a budget putting my 350 in for now so imma go with the shorty block huggers, my ? is what brand or size fit properly if yal can help me it could save me a few trips to the hot rod shop. thank you
 Post subject: Re: shory headers?
PostPosted: Sun Oct 25, 2009 10:34 am
from what i have heard alot of people use the old style ram horn manifolds.
if you are working with a budget then you could probably find a decent set of these at a junkyard
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sun Oct 25, 2009 9:31 pm
You need to do some serious measuring. The shorty headers can come out right above the cross member. You might need to do a engine test install first... Camaro style exhaust members might be better, they face toward the rear of the engine. That is one reason Hooker made the engine mounts too. It would work together. Factory exhaust manifolds should be cheep at your local salvage yards.
PostPosted: Sun Oct 25, 2009 10:00 pm
I used Hooker block huggers , but as stated you need to measure and test fit . I fabbed all my mounts from scratch .
PostPosted: Mon Oct 26, 2009 5:59 pm
I ordered the motor mounts and tranny mount from old rob on here those are the mounts imma have in there. so it looks like imma be test fitting and measureing when they come in. thanks everyone for all your help.
PostPosted: Mon Oct 26, 2009 6:07 pm
Doesnt hooker make a kit for a v8 conversion?
PostPosted: Mon Oct 26, 2009 11:58 pm
yeah but the headers are a lil outta my price range for know im lookin for some under $150.
PostPosted: Tue Oct 27, 2009 12:59 am
www.powerbyace.com has under chassis headers available, however they are a little pricey also, approx $ 370.00, they do include the exhaust reducers though.
PostPosted: Wed Oct 28, 2009 7:45 am
Old Rob that is not bad a bad price. 1 piece all under one chassis?
PostPosted: Sun Nov 01, 2009 8:17 am
with those under chassis headers do i gotta take out my torsion bars and run coilovers?
PostPosted: Mon Nov 02, 2009 9:31 pm
Hooker has quit making those. They sold the last 5 sets to Summit I think, maybe Jegs. Used ones can be found sometimes. The kit info is off the main site.
http://www.luvtruck.com/Information.htm
PostPosted: Sat Nov 07, 2009 8:27 am
My shorties came out over the crossmember also I used to have but they did get the exhaust pipe bent and bolted right up. still have the brand new pipe that is bent to fit mine. if you use shorties and the pattern is the same you can have the pipe just for the shipping.
PostPosted: Sat Nov 07, 2009 8:04 pm
Im going to order the summit brand block huggers and hope they fit/make em fit. Do you remember what brand you used?
PostPosted: Sat Nov 07, 2009 9:18 pm
I'm not sure what they are but I still have them here and they are ceramic coated if you might be interested in them. Just PM me if you might be. I also have a set of almost new flowmaster mufllers.
I went to the hooker long tubes and 3 inch exhaust.
PostPosted: Fri Nov 13, 2009 1:38 am
The headers from ACE are designed for use with the stock front suspension. The front header tube comes apart so the they can be installed without removing the torsion bars. They do not interfer with the stock oil filters or E brake cable either. These are 3/8" flanges at the head and collector, 1 5/8" tubes with three inch collectors. Better for the street than the 1 3/4" tubes.
PostPosted: Sun Feb 21, 2010 11:09 pm
i was curious if people could add some pictures of their block huggers or stock style manifolds please. ive been looking into block huggers myself.
im just wanting to see clearances and such
PostPosted: Mon Feb 22, 2010 6:19 am
I still have my ceramic ones. I got them back from my son when he sold his truck. PM me and I will send you my pics. I still have the bent pipes that hook to them. Clearance is a little tight but don't rub anywere. I had them on mine when I still had the torsion bars on.
I am in JC. I was just in KC this weekend and will be going back soon I think.
PostPosted: Mon Mar 22, 2010 4:24 pm
PostPosted: Mon Mar 22, 2010 5:46 pm
See ya got a good pic of them up. Glad you got them and hope they serve you well. :) 8)
Thanks, Rick
PostPosted: Sun Apr 18, 2010 10:08 am
hey old rob im buying my headers from ya on friday i was wondering if those fenderwell exit headers fit on a 76 2wd luv.
Users browsing this forum: Baidu [Spider] and 24 guests
