It is currently Fri Dec 26, 2025 1:49 pm
PostPosted: Sun Sep 27, 2009 8:49 am
hey fellas i bought a new stock creat motor for my 79 luv. i need to know if i have to replace my clutch plate. well i need to know what all i will have to replace?
PostPosted: Sun Sep 27, 2009 9:43 am
When installing a new/re man motor it is always wise to replace the clutch asy.and machine the fly wheel.It's allot easier to do it now then do it later and if the clutch was marginal to start with the rise in power from a new motor will take it out in a hurry.
PostPosted: Sun Sep 27, 2009 10:57 am
Check you local auto parts store. I was able to buy a new clutch and reman fly wheel for surprisingly cheap. I don't remember how much, but I was impressed with the cost.
PostPosted: Sun Sep 27, 2009 12:46 pm
If you have the engine on the stand you can always take the clutch you have to the parts store and use a set of micrometers to measure the difference in thickness (wear) between it and a new one. If the wear is noticeable then I'd definitely replace it.... Clutch, pressure plate and release bearing. While you're there you might as well replace the front seal in the tranny. Definitely resurface or replace the flywheel if you replace the clutch.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Sep 27, 2009 1:32 pm
Do it now or you will wish you did
PostPosted: Sun Sep 27, 2009 3:53 pm
If its a 2x4 My honest opinion is that if its working OK and looks OK put it back in and keep using it.
Its about a 2.5hr job to change the clutch in a 2x4 once its worn out.
Depends on cost, you guys in the US get pretty cheap parts so a new one is probably a good idea. Your looking at well over AU$100 here for a clutch.
Cheers, Bob.
PostPosted: Mon Sep 28, 2009 10:23 pm
OK SAY I DONT REPLACE MY CLUTCH HOW LONG DO YOU THINK IT WILL LAST
PostPosted: Mon Sep 28, 2009 11:34 pm
30 min.. :ebiggrin
LUV is...
PostPosted: Mon Sep 28, 2009 11:36 pm
How long is a piece of string????
Might last 30mins might go for 10 years.
Depends how good it is.
Bob.
PostPosted: Tue Sep 29, 2009 6:01 pm
It's really simple to measure it compared to a new one lying on the counter next to it and most parts stores will do it for you as long as you bring in the old one and they have the new one in stock. If I was this torn over "whether or not" I would probably replace it.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Wed Sep 30, 2009 10:14 pm
ok i will replace it . im just trying to cut cost ass mush as i can for now . im not working and its really hard without this truck so i got to get her back up and running so ill go and get a new one and have it put in anyone know what size i need for this truck its a 79luv manual. i looked on e bay i saw a few but there was two sizes what will be the difference between going to a bigger one will this help in some way. o ya if yall cant tell im NEW AT THIS.
PostPosted: Wed Sep 30, 2009 10:31 pm
They sell clutch sets for every year except '72 at NAPA (or Kragen, O'Reilly, whatever). You can only have one size of clutch on a LUV, it's not like the bigger Chevys where there are 11 and 12 inch clutches.
PostPosted: Thu Oct 01, 2009 12:13 am
What size??? The size that fits your flywheel.
If money is tight, your best bet would be to load up some pictures and/or take the clutch to someone who can inspect it for you. Get an idea on its condition.
No point spending $100 on a new when the one you have got could get you to the point where your have a $100 to spare.
Cheers, Bob.
PostPosted: Thu Oct 01, 2009 12:16 am
Not to change the subject, but where'd you get the motor?
PostPosted: Thu Oct 01, 2009 9:22 am
i got the motor from www.gearheadengines.com
