It is currently Mon May 25, 2026 6:47 am
 Post subject: Oversized pistons
PostPosted: Mon Sep 14, 2009 8:05 pm
Those of you that bored your engine, where did you get the oversized pistons?
 Post subject: Re: Oversized pistons
PostPosted: Mon Sep 14, 2009 8:08 pm
Got mine from Kragen.com. I had to order pistons for a Impaulse though.
PostPosted: Mon Sep 14, 2009 8:32 pm
did you buy just stock or regular sized pistons under the impulse??
PostPosted: Mon Sep 14, 2009 10:07 pm
They did not list oversize pistons for the LUV, the impaulse work but up the compression I think a half point.
PostPosted: Tue Sep 15, 2009 6:28 pm
So you bought the standard sized pistons for the impulse??
PostPosted: Tue Sep 15, 2009 6:33 pm
You can, the Impaulse is a G180 engine with higher compression, same rods and block.
PostPosted: Wed Sep 16, 2009 3:39 pm
Ok cool, thanks
Users browsing this forum: Bing [Bot] and 22 guests
