It is currently Tue May 26, 2026 1:00 am
 Post subject: Oversized pistons
PostPosted: Mon Sep 14, 2009 8:05 pm
Those of you that bored your engine, where did you get the oversized pistons?
"If it wont fit, force it, if it breaks, then it needed to be replaced anyway..."
 Post subject: Re: Oversized pistons
PostPosted: Mon Sep 14, 2009 8:08 pm
Got mine from Kragen.com. I had to order pistons for a Impaulse though.
PostPosted: Mon Sep 14, 2009 8:32 pm
did you buy just stock or regular sized pistons under the impulse??
PostPosted: Mon Sep 14, 2009 10:07 pm
They did not list oversize pistons for the LUV, the impaulse work but up the compression I think a half point.
PostPosted: Tue Sep 15, 2009 6:28 pm
So you bought the standard sized pistons for the impulse??
PostPosted: Tue Sep 15, 2009 6:33 pm
You can, the Impaulse is a G180 engine with higher compression, same rods and block.
PostPosted: Wed Sep 16, 2009 3:39 pm
Ok cool, thanks
Users browsing this forum: Google [Bot] and 33 guests
