It is currently Mon Jun 08, 2026 4:11 am
PostPosted: Sat Jun 20, 2009 7:35 pm
alright i went to the last socal luv meet and luvr8 told me that my fan cluch was bad so i got a new clutch and put it on right and took it for a test drive up azusa cayons still runns hott but i found a nice photo opp place so if we ever do a cruze up the cayons from azusa to glendora mountian road which i think would be fun back to the subject hopefully thursday i can go buy an new theromastat and put it in my truck but other that chnageing that anyhitng else and i feel better knowing my fan works now :o
75-luv mikado-V8 350 soon
PostPosted: Sat Jun 20, 2009 8:40 pm
Many things tie into engine cooling, check your timing, is the radiator any good, it may need roding out, how is the radiator cap? There is no one thing to say "that will run cooler", look at the big picture.
PostPosted: Sat Jun 20, 2009 8:52 pm
Glad you figured out what he was asking, I got lost with all the misspellings and one huge run on sentence!!!!
:esurprised
PostPosted: Sat Jun 20, 2009 10:44 pm
:lol: You read my mind..
PostPosted: Sun Jun 21, 2009 12:59 am
lol some one had to figure it out
PostPosted: Sun Jun 21, 2009 5:57 am
Where did you get the new fan clutch? And is it just like the old one?
PostPosted: Sun Jun 21, 2009 12:19 pm
i got it from dicks auto in azusa off azusa ave off the 210. its bolts right to the fan but the way it bolted to the water pump was a lil differnt but theres a adapter thats on the water pump for the old clutch i just took that off and than the 4 bolts that gointo the pulleys and the clutch just bolted to those four bolts. it was like $55 it is also a spiecial order part thojust have to wait a day. and also the clutch sticks out farther than the old one less of clearance on the raditor but theres enough
PostPosted: Sun Jun 21, 2009 2:06 pm
OK. Sounds like the same one that my parts store got for me. I think they are actually for an 81/82 LUV and PUPs. But for some reason when I to put it on my 80, I ran out of room. Probably the 3 row radiator I have on it.
PostPosted: Sun Jun 21, 2009 6:02 pm
yeah i almost ran out of room
PostPosted: Mon Jun 22, 2009 8:56 pm
i think the raditror off my 75 luv is in better shape will it work on my 77?
PostPosted: Tue Jun 23, 2009 12:15 am
The radiators were shorter in the 72 - 75 trucks. If you look at bottom of the core support you can see if they both go forward and the radiator sits behind. The 77 does.
PostPosted: Tue Jun 23, 2009 10:53 am
Also I know you don't have a coolant overflow...get one. Lastly, since your AC is broken, you don't really need a clutch fan at this point so you could go to a solid fan for testing purposes, in case you are afraid that even your new fan clutch is no good.
PostPosted: Tue Jun 23, 2009 10:28 pm
no its good it doestn spin like the last one and i found out the hard way on the raditor swap lol and how much coolant does the luv hold i put 2 liters in it and the raditor is full but im waiting till the threo opens up so i get a full system
PostPosted: Tue Jun 23, 2009 10:33 pm
Make sure to turn your heater on when starting a drained engine, the heater core needs to be bleadn as well.
PostPosted: Tue Jun 23, 2009 10:52 pm
my heaters "always" on/ when it wants too
Users browsing this forum: Google [Bot] and 29 guests
