It is currently Mon Jun 08, 2026 6:45 am
 Post subject: Relay for accessories?
PostPosted: Fri Jun 19, 2009 9:55 am
I've read the ignition switches on these trucks can go bad, e.g.
viewtopic.php?f=24&t=18453&hilit=ignition+switch
and that when you put in a stereo sometimes you can wire it directly to the battery to save the accessory line on the ignition switch from melting,
viewtopic.php?f=5&t=19405&hilit=ignition+switch
my question is, say I want to put in a fairly powerful CD/MP3 head unit, why not use the accessory wire to drive a relay which then brings power to the radio, which is on an inline fuse from the battery or fuse block? That way I can simply size the relay correctly to supply power to the head unit, and not burn out the ignition switch driving some 6x9s and a set of 4.5s. That's what I'm planning in the future for speakers.
Anybody done this?
PostPosted: Fri Jun 19, 2009 11:37 am
I wired it to the acc wire and you saw the bunch of speakers I had. Plus the amp and woofer. Oh, and at night I also turn on the stock radio( just cus I like how the green light looks), so I have two stereos running on the acc wire. I always have the stereo full blast and never had a problem with it, no melted wires or anything.. 8)
LUV is...
PostPosted: Fri Jun 19, 2009 11:52 am
Anybody done this?
That will work just fine & dandy! While you're at it do the same for your headlights and you'll have brighter lights running battery-direct!
PostPosted: Sat Jun 20, 2009 11:08 pm
I think I might just go ahead and do that.. :ebiggrin
LUV is...
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 64 guests
