It is currently Mon Jun 08, 2026 4:12 am
 Post subject: oil dipstick
PostPosted: Fri May 29, 2009 10:18 pm
does any body have an oil dipstick for a 1.8L engine it seam like the one in my engine is not long enough
of course it hurts you are being screwed by an elephant
 Post subject: Re: oil dipstick
PostPosted: Sat May 30, 2009 9:24 am
Check to make sure the rubber seal in still in the correct place. While going through my engine for cleaning and tunning up, I found mine to be missing the rubber seal. My oil reading was WAY over full since the dipstick slid in too far. I used some rubber hose and RTV to fix the problem. Changed the oil and filter, ran it a bit, let it sit, and when I checked the oil, the level was spot on....
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat May 30, 2009 1:31 pm
also you much check the oil 3 to 4 times to get the right reading... it will jive a false reading the 1st or second time you pull it...( i think it get air in the tube)
PostPosted: Sat May 30, 2009 10:07 pm
Try pulling off the filler plug off of valve cover this allows the oil in the pan to equalize in the tube. Sounds crazy but it works.
PostPosted: Fri Jun 19, 2009 1:44 am
and make sure its the right one when i got my luv it had the older dip stick in it so i got the rite one dam it was way better lol
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Mon Jun 22, 2009 11:24 am
With my original dip stick, I always had to pull it out then put it back in to get a good reading. Don't ask me how, but I lost it. I made a new one. I used some heavy wire. I flattened it and put a cross hatch on it in my vise. I soldered the insides out of a AA battery on the wire open end down. The battery thing fits over the tube. I then changed the oil and marked the full mark.
Users browsing this forum: Google [Bot] and 26 guests
