It is currently Sat Jun 27, 2026 6:42 pm
 Post subject: 1.8 rebuild kit
PostPosted: Wed Mar 19, 2008 3:33 pm
hey does any one know where to get a complere rebuild kit for a g180? i need a compleet gasket set and pistons and i think io will be good but if the kit comes with a new cam thats good too
 Post subject: Re: 1.8 rebuild kit
PostPosted: Wed Mar 19, 2008 7:49 pm
:) Napa is the place to get just about all internal engine parts needed for your rebuild. pistons.rings,bearings,full gasket kit,camshaft,timing chain,oil pump,reman head,valves etc!!!!
hope this helps!
Mike.
PostPosted: Wed Mar 19, 2008 7:55 pm
oooh so you have already rebuilt yours?
do you mind if i asked what you paid for it? 8)
PostPosted: Thu Mar 20, 2008 12:32 am
northern auto parts online has a kit they are known for low price quality rebuild kits might not hurt to check them out I didn't check I know they have it on there site though.
PostPosted: Sat Mar 22, 2008 12:07 am
without a rebuild kit, i've put well over 1300 into rebuilding my 1.8. only because the gasket recently blew again so i spent about 300 resurfacing/valve job/ etc on the head and buying new head bolts and a head gasket set.
we had everything imaginable done to the engine when we rebuilt it, except we didn't get new pistons, mine were in good shape, or a cam or anything. almost everything else is spankin new.
but with the kit im pretty sure it'll be way cheaper than what i payed.
PostPosted: Sat Mar 22, 2008 11:18 pm
ooh yeah! you can usually pick up a complete kit for around $350-400$ that includes all new bearings,pistons,rings,gaskets,etc....
PostPosted: Mon Mar 24, 2008 8:38 pm
I just pulled my eng. out and took it to a rebuilder. They will check all clearances and do any machine-ing (sp?) needed. I paid a grand, and put it back in the truck myself. 12 thousand mile warranty, too.
PostPosted: Sat Mar 29, 2008 9:20 am
Well...I hope I don't make any of you mad.
I bought my 80'2WD from a farmer that had it sitting in his field for $80. Belonged to his brother that had passed away, and the only thing missing was the drivers door glass(vandals). I hang around a machine shop near the house and do grunt work for the owner(teardowns, sweep the floors, fetch wrenches,etc...)and he bought me a rebuild kit from one of his suppliers for $304, did the machine work gratis(reworked the head with new valves and seats and guides, polished the crank,and did the assembly)and all totalled I have less than $300 in it. Gas around here is already at nearly $3.50/gal
Under the dash it is VIRGIN. Nobody has ever cut or taped a single wire, brakes are good, all the lights work, and there is very little rust on the body anywhere. I've been staying out in the shop late in the evenings with a buffer and a can of wax and it's coming along fine. Only body part that I'm going to need to replace is the front bumper where someone had used a chain to pull something with and got it bent.
Happy, Happy, Joy, Joy.
PostPosted: Wed Apr 09, 2008 4:46 pm
haha feel lucky for that. gas prices here are as of now 3.99 at some places
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Tue Mar 17, 2009 3:59 pm
I am a newbie, i just got my very first luv for free and it looks freakin NEW!!! i am starting the rebuild next week i can't wait.
PostPosted: Wed Mar 18, 2009 10:36 pm
tramp.. rosco... it sounds like you both scored pretty good in getting your trucks.
PostPosted: Thu Mar 19, 2009 12:38 am
looks to me like people dont look at dates when they draggin up old threads :esurprised
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Fri Mar 20, 2009 10:41 pm
refering to?
