It is currently Wed Jul 01, 2026 10:42 am
 Post subject: Engines
PostPosted: Sat Mar 14, 2009 11:28 pm
What engines will drop right in to my 79 4x4 and bolt up to my trans
I know the 1.9 2.3 and the 2.6 will is there any others and which is the easiest to do
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
 Post subject: Re: Engines
PostPosted: Sun Mar 15, 2009 10:27 am
The 1.9 is a direct replacement, all the engine accessories & the flywheel/clutch/starter/engine plate from the 1.8 all swap. With the 2.3 or 2.6 you need to use the accessories from that style engine (including the fan & shroud), the clutch (should be the same as the LUV), starter, engine plate & flywheel from a 2.3 (not a 2.6), & the firewall has to be modified to clear the top rear mounted distributor. Plus you need motor mounts for the 2.3/2.6 & they may or may not have to be modified.
PostPosted: Thu Apr 09, 2009 8:39 pm
Are the engines you are referring to-- GM engines or Isuzu engines? I just picked up one of these trucks (an 81) and need to find a suitable, cheap replacement.
PostPosted: Thu Apr 09, 2009 8:48 pm
Welcome. Where are you located?
PostPosted: Thu Apr 09, 2009 9:23 pm
Billings Montana... Where the economy is still hoppin'
PostPosted: Thu Apr 09, 2009 10:37 pm
Well yea, when the population is 9, all 9 people have work. :lol: JK. Montana is a beautiful place. My wife might drag me up that way when we retire in 20 or so years.
By stating where you are, it will help find an eng. near you, maybe.
PostPosted: Fri Apr 10, 2009 6:46 am
Well thank you, that is cool. While it is true that there are many real places up here with a population of ... nothing, lol, Billings is 100,000. Not too big by most standards, but just perfect.
PostPosted: Fri Apr 10, 2009 1:31 pm
:signiagree
I want to get out of this hell hole I live and move to Biliings, reminds me of a mini Denver. 8)
Users browsing this forum: Baidu [Spider] and 23 guests
