It is currently Wed Mar 25, 2026 10:43 pm
PostPosted: Fri Mar 06, 2009 6:48 pm
I have gone over all the grounds and everything appears to be solid
any ideas as to what it might be?
if not im just going to re-wire the mother
:| :!: :x :) :( :ebiggrin :econfused :roll: :idea: :idea:
Image Image
PostPosted: Fri Mar 06, 2009 8:14 pm
Post Moved! :roll:
PostPosted: Fri Mar 06, 2009 8:58 pm
if you have a volt meater and now how to use it you can find it that way it may not be a ground it may be a bare going through the fire wall i had the same problem it ended up being my fule pump wire
PostPosted: Fri Mar 06, 2009 9:38 pm
Which fuses are blowing?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Mar 06, 2009 11:55 pm
The second fuse
i also just checked to see if it was my fuel pump wire, unfortunatly for me it wasnt
Image Image
PostPosted: Sat Mar 07, 2009 12:36 pm
Sinse it appears to be in the lighting circuit, you need to unplug all the lights--both tail lights, front park lights, etc. It could be something as dumb as a bad bulb. If it dosen't blow the fuse untill you go to the headlight position of the switch then unplug both headlight bulbs and try again. Plug the lights/bulbs in one at a time until you find the one blowing the fuse. A bulb that is black is definately bad.
If you find nothing there keep in mind the instrument panel lights also come on with the light switch so could be a problem there. Noting if the fuse blows in the "park light" position or the "headlight" position should help you narrow it down.
PostPosted: Sat Mar 07, 2009 7:30 pm
hm...luckily i just bought more fuses so ill test your theory and see if thats the problem
i have a couple of reasons that lead me to believe that this might be the cause
:lol: your right it is dumb
but if it fixes my problems
ill let you guys know
:ebiggrin
Image Image
