It is currently Sun Jun 28, 2026 5:53 am
PostPosted: Wed Feb 11, 2009 10:04 pm
I just bought my 78, the only problem is the gas tank leaks if i fill it more than half way. It is the two piece gas tank. Anyone know where i can get a gasket or maybe is there any easier fix?
PostPosted: Wed Feb 11, 2009 10:13 pm
I think I would try j b weld if your trying to find a quik fix. I put a amp in the trunk of my 76 Monte Carlo and I drilled through the bottom and through the gas tank so I dropped the tank and put j b weld and put it all back 2gether and let it dry and it don't leak any more
currently working on my 1977 luv truk
PostPosted: Sat Feb 14, 2009 1:15 am
yeah, i could try that. if worst comes to worst ill just get a small fuel cell.
PostPosted: Sat Feb 14, 2009 5:07 am
Go to a NAPA store they usually have a two part epoxy that is made specifically for repair of fuel tanks and you can put it on with the fuel running out even. I have used the stuff several times and it works good and permanent.
PostPosted: Sat Feb 14, 2009 6:03 pm
Any one know how many galons the tank can hold?
I can only put 5.....
PostPosted: Sat Feb 14, 2009 8:12 pm
10 gallons 72-75, 13.2 gallons 76 and up
PostPosted: Sat Feb 14, 2009 9:36 pm
i guess the gauge must be marking it empty a bit early
next time it marks emty i'll try to siphon it out and see if i can get 5 gallons out of it
PostPosted: Sun Feb 15, 2009 8:48 pm
Thanks guys, ill try that epoxy...sounds a little better than a buying a whole new fuel cell.
Users browsing this forum: No registered users and 60 guests
