It is currently Tue May 26, 2026 5:06 am
 Post subject: BODY MODS
PostPosted: Fri Jan 30, 2009 9:41 am
Hey guys id like to see all your pics of body mods like shvaed seems, roll pans, etc...Also if anyone knows how to shave the chevrolet off of the tailgat, and set the licence plate in the tailgate, id like some info on how to do it thanks.
 Post subject: Re: BODY MODS
PostPosted: Sun Feb 01, 2009 9:53 pm
wow no one has done any body mods?
PostPosted: Sun Feb 01, 2009 10:13 pm
you can click on my pic below and see some mods i did on my truck, also check the other step sides to see some mods... then you can click on here http://www.chevyluv.zoomshare.com/ to see some how-to info
PostPosted: Mon Feb 02, 2009 10:25 am
thanks ctmandu
PostPosted: Sun Feb 08, 2009 12:12 pm
shortened bed about 16 inches. shortened frame about 12 inches
Juice
PostPosted: Sun Feb 08, 2009 12:15 pm
oh yeah it's also a tilt bed dump truck.
Juice
PostPosted: Sun Feb 08, 2009 7:46 pm
Nice bed, I like it :ebiggrin
PostPosted: Mon Feb 09, 2009 1:18 am
shaved the rear on my bagged luv
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Feb 12, 2009 9:37 pm
those are both pretty sweet, how hard is it to shave your bed like that?
PostPosted: Thu Feb 12, 2009 11:32 pm
Hardest part of it is getting all the metal straight and aligned, then theres a ton of welding and grinding that follows. Took two days in just welding and grinding and a week of bodywork.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Feb 14, 2009 8:46 am
Thats alot I want to shave the hooks off my bed, do a grant kustoms shaved tailgate and roll pan.How hard is it to shave the hooks?It seems easy but I dont know alot about body work.
PostPosted: Sat Feb 14, 2009 8:54 am
Grind them off, it's that easy.
PostPosted: Sun Feb 15, 2009 3:03 pm
sweet
PostPosted: Sun Feb 15, 2009 3:10 pm
Aside from filling in the gas filler hole and emblems removed I wanted to keep my LUV as stock as possiable on the exterior, kind of different I guess. I do like the shaved tailgate, thats the ony thing different I would do.
PostPosted: Tue Feb 17, 2009 10:22 pm
yea I know what you mean.I want mine pretty close to stock I just want to clean it up and update it alittle.
PostPosted: Wed Mar 18, 2009 8:04 pm
my 76 has alot of mods but i did not do any of them i bought already finished
it has filler panel welded in on top of the front bumper, custom chevy emblem marker lights in front fender, custom cowl hood, shaved door handels, custom mirrors, pro tops hardtop convertable kit, frenched power antenna, shaved bed hooks, shaved fuel filler door, custom vents molded into lower bed sides, shaved tailgate, shaved tailgate latches, shaved emblems
Image Image Image Image Image
PostPosted: Fri May 15, 2009 4:22 pm
If your tailgate had CHEVEROLET stamped 'into' it, fill it with bondo. I did that on one and it lasted for three years and was still smooth without cracking when I sold it. I used a fiber-filled bondo to start and then standard bondo for the final coat. Finished with a long sanding block and sprayed light coats of flat black on it so I could see the high/low spots.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Fri May 15, 2009 5:06 pm
:signnoway Sorry, there is a right way to do things and a wrong way, and that is definatly the wrong way. Dont hack your ride. Like my sig says.......
PostPosted: Fri May 15, 2009 7:54 pm
Didn't say it was the best way! :oops: Cheapest way - probably :P
We did one by cutting metal to the shape of the letters and welded them in place, followed by bondo to smooth it out. Just made sure they sat a tad below the level of the tailgate. Just took a lot of time to cut the peices out. Another way would be to cut the center section just outside of the letters out and weld in a blank piece. With both of these methods be careful about warping the metal with excessive heat. I didn't have a wedling machine back then so my friend did his own letters, then I got it to smooth out.
Never heard of anyone replacing the entire center section though!
Rick
Loranger, La
PostPosted: Fri May 15, 2009 8:40 pm
:signiagree :smt023 Thats the right way to do it.
No offense to your original post but half@ss customizing is another pet peeve of mine. I see way to many vehicles ruined because people dont take the time or money to do it right (and or safe).
